I have been trying to find a way to correct the glitch of dsmr values that cause the utility meter. They jumped from 1485 to 619.234 kwh…
So how do I correct the state of the utility sensors (daily, weekly, monthly, yearly)?
The last version has a description of it in its release notes, since the feature has just been released
Calibrate service
@nikito7 thanks for pointing out the calibrate service, I just tried it. But it does not change the state value of the utility meter at all. Don’t understand why.
I did find this: Utility_meter glitch
But I would not know how to do this manually, and instructions are not enough for me right now.
@WallyR I think you are referring to the fact that in the last release there is a new way of changing long-term statistics, right? I will go and try that, I don’t think it will work for the utility meter, but not sure.
That was what I meant, yeah.
Maybe I misunderstood you description.
Yep, yeah, that worked out. Thanks that worked, I had to find the correct sensor name and figure out the correction. It does not clean up history. For now I will accept that. Hopefull that won’t bite me later on.
You could eliminate future “glitches” using the Filter Integration…
