Is there a way to downgrade ESPHome?
I have tried to restore older images, but when I do so ESPHome fails to start because it tries to write to a directory that doesn’t exist.
I just need to install a previous version to test some behavior that has changed
How are you running esphome? The addon?
Yes as an add on
Did you find a way?
I am also curious if there is a possibility to downgrade
Restore a backup with the version you want.
It’s quite easy… I made a quick tutorial on how:
Theres an addon that makes it quick and easy.
