Is there any way to connect Firebase to Hassbian
Hello, I am trying to configure firebase with Hassbian so I can keep track of all the switch and system which is ON and OFF right now. Also if needed I can control it on real time with that. I got a little script created in NodeJS for the same to run in the background using PM2.
But seems like I am unable to do that properly as my structure of the mobile app I created is quite different.
So If someone can suggest any package, that will be helpful.
If needed I can share my code and firebase structure with you guys.
Thank you!
Can you explain how you want to connect Firebase, and why you think you cannot connect it with Home Assistant?
Thank you for showing interest to my question.
I am trying to use Firebase realtime database to perform both side task, if an MQTT request sent from my local device, I will send the update to firebase and once the firebase value is changed it will send an MQTT message (turn on light or turn off light).
Thats the only purpose. So I can control my home automation from distance location as well. Without exposing my system to internet and can be access from my own mobile application as well. As Firebase have authentication in-built as well.
So why do you think it’s not possible to use with hole assistant?
I’m trying to figure out what issue you have.
Because I can not find any module. And not able to understand how can I do it, directly from the UI interface. Is there any way to do that?
Why do you need a module? I am confused on what EXACTLY you are looking for here. You want to connect something like this you are going to have to write some code.
There is nothing directly in the UI.
hi @nehulagr, I was wondering about exactly the same thing. I don’t feel comfortable opening a door in the router so I’d rather keep the states in sync with firebase/firestore.
I’m completely new to HA so I would not have a clue where to start. Did you manage to understand how to do it ?
cheer
I am trying to create NodeJS script to execute in the background. So with PM2 (run nodejs script in the background). I got it ready with maximum logic, there is only one problem I am facing, once that is done I will share with you.
Interesting approach. I was thinking something more similar to the google pub sub component . If that component supported “sub” then a couple of cloud functions would do the trick…
Yes that should also work. But I find NodeJS more easy to work with. I have having some trouble using it on both the sides. I have the script ready, but not 100% working perfect. Also it will more dependent from JSON structure you will create. If you can share the JSON structure then I will share the script related to it.
What about something like this ?
"""Sync with firestore"""
import logging
import os
from typing import Any, Dict
from homeassistant.const import (EVENT_STATE_CHANGED, STATE_UNAVAILABLE, STATE_UNKNOWN)
from homeassistant.core import Event, HomeAssistant
_LOGGER = logging.getLogger(__name__)
REQUIREMENTS = ['firebase-admin']
DOMAIN = 'google_firebase'
def setup(hass: HomeAssistant, yaml_config: Dict[str, Any]):
    import firebase_admin
    from firebase_admin import credentials
    from firebase_admin import firestore
    certificate = os.path.join(hass.config.config_dir, 'firestore.json')
    cred = credentials.Certificate(certificate)
    firebase_admin.initialize_app(cred)
    db = firestore.client()
    col_ref = db.collection(u'states')
    def update_firestore(event: Event):
        new_state = event.data.get('new_state')
        old_state = event.data.get('old_state')
        if (new_state is None
                or new_state.state in (STATE_UNKNOWN, '', STATE_UNAVAILABLE)
                or ( not new_state.entity_id.startswith('light.')
                     and not new_state.entity_id.startswith('switch.'))):
            return
        col_ref.document(new_state.entity_id).set({u'state': new_state.state})
        # col_ref.document(new_state.entity_id).set(new_state.as_dict())
        _LOGGER.debug('added to firestore id %s, from %s to %s',
            new_state.entity_id,
            old_state.state if old_state is not None else None,
            new_state.state)
    def on_snapshot(col_snapshot, changes, read_time):
        for change in changes:
            id = change.document.id
            state = change.document.to_dict().get('state')
            if state in ['on', 'off']:
                method_string = 'turn_' + state
                _LOGGER.debug('Calling homeassistant.%s %s', method_string, id)
                hass.services.call('homeassistant', method_string, { 'entity_id': id })
    query_watch = col_ref.on_snapshot(on_snapshot)
    hass.bus.listen(EVENT_STATE_CHANGED, update_firestore)
    return True
Hi Everyone,
Big thread coming, i’m new to HomeAssistant. And i also want all my devices offline, with some private online access. Or at lease having the control of the data. As HA say “Open source home automation that puts local control and privacy first” :grinning: !
I did take a look around and see other app, but none support Firebase. And also I don’t want to open any port, public IP etc…
So I make a quick POC syncing HomeAssistant database and Firebase.
Using @payano repo https://github.com/payano/homeassist-ng (A native android app).
The result is:
  • Sync all Entity with Firebase OK!
  • Using node-red with the firebase-contrib-plugin, turn on/off light OK!
Now the issue (or next step) is, I don’t want to configure node-red for every Entity. Maybe there is a way to pass data. But I think it’s better having HA handle firebase and consume the state light " on data change.
So, can someone help me on server side doing the following:
I’ll make the client side :
  • Add a toggle button “Go Online” (Need to discuss with @payano )
  • Switch app locale database to the firebase one if online.
  • Stop locale connexion while online, probably change the data source.
  • Make firebase config dynamic, actually firebase need a google-service.json at compile.
    Meaning anybody that want to used their own Firebase, will need to compile the app :frowning: .
  • I should be able to use cloud messenger for notification.
  • If I can’t removed google-servives.json, I’ll have to make a little bash script for installation if people are interested.
So at the end, would be nice if someone could handle the server side (@seba, @nehulagr, @anybody :grinning: ).
How does it sound, do you think I can go with that ?
Hello @Fraid, interesting approach! If the community wants it, I think it should be implemented.
I am doing refactoring in HomeAssist-ng, with one class HomeAssistant (HA) with a ConnectionHandler, which will be able to connnect the HA instance over different connection methods.
HomeAssistant have a data member: ConnectionHandler. ConnectionHandler have a list of EndPoints to use for connecting to HA.
[HomeAssistant] (Singleton) (Handles the configuration layout and states of all the items configured in HA)
  • [ConnectionHandler] (Handles the connection to HomeAssistant, have one or more EndPoints to connnect to the HA instance)
    • [HaWebSocketEndPoint] (Connects to HA over the WebSocketAPI) # currently working on this
    • [NabuCasaEndPoint] (Connects to HA over NabuCasa) # this is something that would be nice to have.
    • [FirebaseEndpoint] (Connects to HA over Firebase) # this is new
[GUI] Will request the HomeAssistant singleton for information and publishes it in the GUI for the user.
I’m thinking of having multiple connection endpoints configurable for the user in the settings view in the HomeAssist-ng application, the user can choose to have one or more endpoints configured, the user must atleast have the WebSocketAPI configured. When the user is connected to the LAN where the HA instance resides, the user will then be connected to HA over WebSocketAPI, if the network is changed and the user can no longer connect over WebSocketAPI, then the app will try the other endpoints. If it succeeds to connect to the instance, it will use that endpoint until the network connection is changed, then the HomeAssist-ng app will evaluate if it should try the WebSocketAPI.
I’m working on enabling support for LoveLace for HomeAssist-ng over WebSocketAPI, I will also remove the REST API implementation in the application, because the WebSocketAPI supports the publisher/subscriber design pattern which the REST API is missing, it only supports polling. If it is needed in the future, I will create a new endpoint and let it coexist with the WebSocket API so both can be connected to the HA instance simultaneously.
If you want a FirebaseEndPoint, there shouldn’t be any problem from the HomeAssist-ng app, we only need to agree on the data layout and the information that it contains. I would suggest that you also store the LoveLace layout in Firebase, as well as the states. But we can discuss this later on. If the FirebaseEndPoint sends a data structure with states and GUI layout, the application can publish it for the user.
Hi @payano,
Thank for the the interest! Sound good, do you already have like an interface, I can implement the FirebaseEndPoint?
[FirebaseEndPoint] I think we should stick with the same payload as HA, for easy migration, or a new connexion type. Which is what HA-ng does from what I see.
The only part left i think is dynamic configuration for Firebase, I’ll try to take a look at it this week.
[GUI] Lovelace, sure we can put everything in FireBase. But I don’t know much about it, for now in HA I only added my devices. No personalization yet ^^. Currently I’m learning node-red with online tutorial. Because look easier for me. And by the way I discover from HA-ng, i can sent the full payload to node red to make any action.
Hello @Fraid,
The implementation is far from done, but i published the code that i’m working on now on Github (https://github.com/payano/homeassist-ng-refactoring/).
If you want to try it, clone the repository and open the project in Intellij idea. Change url and password token in HAWebSocketEndPoint. The ConnectionHandler is setting up the connection, authenticating, requesting the states and subscribes to events. The interface “HAConnectionEndPoint” have most of the methods needed, if you do progress, please send Pull Requests so i can merge it with the master branch.
Cheers.
Hi @payano,
Just to make sure does the following explain your goal?
HA-NG-EndPoint
Once we are connected to FB, any change will be automatically sync on the device, that mean FBConnexionEndpoint will handle only:
public void setup();
public boolean isOnline();
public void connect();
public void disconnect();
public void send(Payload data);
On the other side we need something like:
HAEventHandler
public void onLayoutDataChange(Entity data);
public void onDataChange(Entity data);
So are we on the same boat, did I miss something ?
Hello @Fraid,
The graphical illustration is a good representation of how the application should interact with other parties, such as a HA Local instance and CloudFirebase, you are spot on!
Regarding the interface, i’m open for suggestions, I have only focused on the retrieving part, for example, getting the states and the gui from HAWebSocket, but as you said, we need a way to also send data from the application to the endpoint, a send(Payload data) is good!
The way I thought would be a nice design is to let the ConnectionHandler be a subscriber to the Endpoints, and when the endpoints have new information they can publish it to the interested parts (most often ConnectionHandler). The ConnectionHandler is sleeping most of the time and when it gets a callback from an endpoint they intterupt the thread.sleep() call. The ConnectionHandler then checks for incoming messages and acts upon it.
Do you think these methods also should be available on the Endpoint interface?:
Cheers :slight_smile:
Hi @payano
This part look “weird” to me, because HAFirebase is automatically sync. When something change you will be notified by onDataChange callback. That look like two task waiting for the same thing.
If you let me this week, I’ll make a bigger picture of what I think of ConnexionHandler.
I started to play with Lovelace, when you say save the layout, is it the yaml file?
Cheers :grinning:
Hi @Fraid,
Your are right, it is unnecessary to have two tasks/threads waiting for this task. I really like having the ConnectionHandler on its own thread and skip the thread inside the EndPoints.
To set/get LoveLace configuration look at this link: https://github.com/payano/homeassist-ng/issues/13
I have created some sketches on how i would like to design the application:
My handwriting can be tricky to read sometimes :stuck_out_tongue:
The first one is how threads communicate:
Here is a class diagram:
Here is a use-case diagram:
Looking forward to see some of your pictures. :slight_smile:
Awesome! We are definitively on the same boat, but not on the same floor :smiley: !
Correct me, if I’m wrong, but I think you’re seeing Firebase as a connexion like system.
However it’s more like a smart Database, the only thing we need to handle is data change on both side server/devices.
If you did know Android, before Glide/picasso library, there was many thing to handle before showing an image from url.
Now you mostly have to do:
Glide.load(«some uri » ).into(imageView)
So same thing for FB
Firebase.listenTo(« /user/home/door1/status »).onChange(«make layout red »)
From documentation :
The Firebase Realtime Database lets you build rich, collaborative applications by allowing secure access to the database directly from client-side code. Data is persisted locally, and even while offline, realtime events continue to fire, giving the end user a responsive experience. When the device regains connection, the Realtime Database synchronizes the local data changes with the remote updates that occurred while the client was offline, merging any conflicts automatically.
Source: Firebase Realtime Database
Knowing that, I’ll suggest something like:
public interface HAConnectionEndPoint {
public void authenticate();
- public void getStates();
- public void getGUILayout();
+ public void waitOnDataChange(HAEvent callBack);
OR (prefer the following)
+ public void waitOnStatesChange(HAEvent callBack);
+ public void waitGUILayoutChange(HAEvent callBack);
public void registerSubscription();
public void unregisterSubscription();
+public void sendData(HAObject data,HAEvent callback);
-public boolean testConfig(String url, String username, String password);
+ //Used sendData method ?
When data has been changed we can call:
HAEvent.onDataChange(HAObject);
[Lovelace] Didn’t really catch it for lovelace but on the server side ( HAFirebase.py i guess) you can send what ever you want. If you have node red installed on HA, i can make a mockup.
And no! I don’t work for Firebase neither have any action of then :D!
