Issue adding ZWave Hub to QNAP 453Be
I am trying to integrate ZWave “Aeotec Z-Stick Gen5, Z-Wave Plus USB” on my QNAP 453be NAS USB3 port and having hard time getting QNAP to recognize it as well as integrating with Home Assistant.
When i SSH into the NAS, ls -1tr /dev/tty* command will show tty device# from 0-60 then have S0, S1, S2 & S3, but no USB0 / USB1 or ttyACM0. I do not see any new USB device added after inserting the Z-Stick.
Also I did confirmed that the cdc-acm module was not loading hence i ran the command and can see it now, but could not find the ZWave Stick.
Experts could you please help!!!
Please help, I am stuck and am not sure what to do next?
Is there a way I can confirm the ZStick Works or can see some logs etc to confirm the issue?
TIA
anyone, please…
Which port are you using? For me only the front port worked.
