bms - can/485 plug. pin 1 and 2 connect to rs485-uart converter. converter connect to esp (tx-rx, rx-tx)
I have doubts about that.
k i tried that setup and no goā¦
BMS pin 1 (B - right most pin next to UART plug on BMS) ā B on TTL to RS485 Device
BMS pin 2 (A - 2nd right most pin next to UART plug on BMS) ā A on TTL to RS485 Device
Then from R0 ā ESP GPIO16 (uart 2 rt) and DI ā ESP GPIO17 (uart 2 tx)
Also tried
R0 ā ESP GPIO17 (uart 2 tx) and DI ā ESP GPIO16 (uart 2 rt)
My config
uart:
tx_pin: GPIO17
rx_pin: GPIO16
baud_rate: 9600
stop_bits: 1
If you can spot any issues with my setup thatāll be great! thanks for your help. Also if you donāt mine, can you post the model of your ESP32, TTL to RS845 board and etc?
[20:33:03][VV][scheduler:226]: Running interval āupdateā with interval=5000 last_execution=422417 (now=427418)
[20:33:03][V][modbus_controller:226]: 2 modbus commands already in queue
[20:33:03][VV][modbus_controller:232]: Updating range 0xD457
[20:33:03][V][modbus_controller:195]: Range : D457 Size: 1 (0) skip: 0
[20:33:03][W][modbus_controller:182]: Duplicate modbus command found: type=0x10 address=54359 count=1
[20:33:03][VV][modbus_controller:232]: Updating range 0x30
[20:33:03][V][modbus_controller:195]: Range : 30 Size: 1 (3) skip: 0
[20:33:03][W][modbus_controller:182]: Duplicate modbus command found: type=0x3 address=48 count=1
[20:33:03][VV][api.service:697]: on_ping_request: PingRequest {}
[20:33:04][VV][api.service:043]: send_ping_response: PingResponse {}
[20:33:07][V][modbus_controller:042]: Sending next modbus command to device 129 register 0xD457 count 1
[20:33:07][VV][uart.arduino_esp32:194]: Flushingā¦
[20:33:07][V][modbus:231]: Modbus write raw: 81.03.00.38.00.0B (6)
[20:33:07][V][modbus_controller:565]: Command sent 0 0xD457 1 send_count: 5
[20:33:07][D][uart_debug:114]: >>> 81:03:00:38:00:0B:9A:00
[20:33:07][D][main:058]: Response data only had 8 bytes!!
[20:33:08][VV][scheduler:226]: Running interval āupdateā with interval=5000 last_execution=427417 (now=432419)
[20:33:08][V][modbus_controller:226]: 2 modbus commands already in queue
[20:33:08][VV][modbus_controller:232]: Updating range 0xD457
[20:33:08][V][modbus_controller:195]: Range : D457 Size: 1 (0) skip: 0
[20:33:08][W][modbus_controller:182]: Duplicate modbus command found: type=0x10 address=54359 count=1
[20:33:08][VV][modbus_controller:232]: Updating range 0x30
[20:33:08][V][modbus_controller:195]: Range : 30 Size: 1 (3) skip: 0
[20:33:08][W][modbus_controller:182]: Duplicate modbus command found: type=0x3 address=48 count=1
[20:33:12][D][modbus_controller:038]: Modbus command to device=129 register=0xD457 no response received - removed from send queue
[20:33:12][V][modbus_controller:042]: Sending next modbus command to device 129 register 0x30 count 1
[20:33:12][VV][uart.arduino_esp32:194]: Flushingā¦
[20:33:12][V][modbus:210]: Modbus write: 81.03.00.30.00.01.9B.C5 (8)
[20:33:12][V][modbus_controller:565]: Command sent 3 0x30 1 send_count: 1
[20:33:12][D][uart_debug:114]: >>> 81:03:00:30:00:01:9B:C5
[20:33:12][D][main:058]: Response data only had 8 bytes!!
[20:33:13][VV][scheduler:226]: Running interval āupdateā with interval=5000 last_execution=432417 (now=437424)
[20:33:13][V][modbus_controller:226]: 1 modbus commands already in queue
[20:33:13][VV][modbus_controller:232]: Updating range 0xD457
[20:33:13][V][modbus_controller:195]: Range : D457 Size: 1 (0) skip: 0
[20:33:13][VV][modbus_controller:232]: Updating range 0x30
[20:33:13][V][modbus_controller:195]: Range : 30 Size: 1 (3) skip: 0
[20:33:13][W][modbus_controller:182]: Duplicate modbus command found: type=0x3 address=48 count=1
Hi What do you mean?
Rs485 converter is not a serial ācommunicatorā, itās a ātranslatorā, so generally tx is connected to tx pin and rx to rx pin.
Like in yours rx goes to RO pin (receiver out).
In your case you also need to control DE and RE pins.
Add this to Modbus:
flow_control_pin: GPIO4
and make a connection from Gpio4 to both DE and RE.
Also make sure you power your converter at 3.3V, not 5V.
ps. use code tags when posting your code or logs
Ah okā¦ thanks for the info. Iāll try thatā¦ I believe the wiring diagram will be closer to this other post (SRNE integration with HA). I was able to get that one to work last night.
Yep.
Just leave the termination resistor there if you donāt have some evidence that is should be removed.
OH YEA!! it workedā¦ Granted thereās a very limited info thatās being presentedā¦
Do you have more sensors/config you can share?
Just request another range of addresses where you have info that you need.
And then pick them one by one like it was done for these four.
Thanks!
K took a while but figure out the patternā¦ in case this helps others
uart:
- id: uart_0
tx_pin: 19
rx_pin: 18
baud_rate: 9600
stop_bits: 1
debug:
direction: BOTH
dummy_receiver: true
after:
delimiter: "\n"
sequence:
- lambda: |-
UARTDebug::log_hex(direction, bytes, ':');
ESP_LOGD("main", "Response data only had %d bytes!!", bytes.size() );
std::string str(bytes.begin(), bytes.end());
if (bytes.size() == 27) {
ESP_LOGD("main", "MATCHED CELL INFO");
ESP_LOGD("main", "Response data %d", bytes[0]);
ESP_LOGD("main", "Response data %d", bytes[1]);
int tv = (bytes[3] << 8) | bytes[4];
id(tbv).publish_state(tv);
int current = ((bytes[5] << 8) | bytes[6]) - 30000;
id(cd).publish_state(current);
int so = (bytes[7] << 8) | bytes[8];
id(soc).publish_state(so);
ESP_LOGD("main", "PLACE HOLDER 0x3B - 0x3D - life, batt qty, batt temp qty");
int maxcv = ((bytes[15] << 8) | bytes[16]);
id(cvmax).publish_state(maxcv);
int maxci = ((bytes[17] << 8) | bytes[18]);
id(cimax).publish_state(maxci);
int mincv = ((bytes[19] << 8) | bytes[20]);
id(cvmin).publish_state(mincv);
int minci = ((bytes[21] << 8) | bytes[22]);
id(cimin).publish_state(minci);
int di = (bytes[23] << 8) | bytes[24];
id(dif).publish_state(di);
if (bytes.size() == 13) {
ESP_LOGD("main", "MATCHED MISC INFO");
int brc = (bytes[3] << 8) | bytes[4];
id(battremaincap).publish_state(brc);
int bct = (bytes[5] << 8) | bytes[6];
id(battcycletime).publish_state(bct);
int bs = (bytes[7] << 8) | bytes[8];
id(balancingstate).publish_state(bs);
int bc = (bytes[9] << 8) | bytes[10];
id(balancecurrent).publish_state(bc);
if (bytes.size() == 23) {
ESP_LOGD("main", "MATCHED MISC INFO 2");
int cmstat = (bytes[3] << 8) | bytes[4];
id(chargingmosstatus).publish_state(cmstat);
int dmstat = (bytes[5] << 8) | bytes[6];
id(dischargingmosstatus).publish_state(dmstat);
int avgv = (bytes[13] << 8) | bytes[14];
id(cvavg).publish_state(avgv);
int pow = (bytes[15] << 8) | bytes[16];
id(power).publish_state(pow);
int ener = (bytes[17] << 8) | bytes[18];
id(energy).publish_state(ener);
int mt = ((((bytes[19] << 8) | bytes[20]) - 40) * 9/5) + 32;
id(mostemp).publish_state(mt);
if (bytes.size() == 61) {
ESP_LOGD("main", "MATCHED CELLS VOLTAGE");
int cv1 = (bytes[3] << 8) | bytes[4];
id(cellv1).publish_state(cv1);
int cv2 = (bytes[5] << 8) | bytes[6];
id(cellv2).publish_state(cv2);
int cv3 = (bytes[7] << 8) | bytes[8];
id(cellv3).publish_state(cv3);
int cv4 = (bytes[9] << 8) | bytes[10];
id(cellv4).publish_state(cv4);
int cv5 = (bytes[11] << 8) | bytes[12];
id(cellv5).publish_state(cv5);
int cv6 = (bytes[13] << 8) | bytes[14];
id(cellv6).publish_state(cv6);
int cv7 = (bytes[15] << 8) | bytes[16];
id(cellv7).publish_state(cv7);
int cv8 = (bytes[17] << 8) | bytes[18];
id(cellv8).publish_state(cv8);
int cv9 = (bytes[19] << 8) | bytes[20];
id(cellv9).publish_state(cv9);
int cv10 = (bytes[21] << 8) | bytes[22];
id(cellv10).publish_state(cv10);
int cv11 = (bytes[23] << 8) | bytes[24];
id(cellv11).publish_state(cv11);
int cv12 = (bytes[25] << 8) | bytes[26];
id(cellv12).publish_state(cv12);
int cv13 = (bytes[27] << 8) | bytes[28];
id(cellv13).publish_state(cv13);
int cv14 = (bytes[29] << 8) | bytes[30];
id(cellv14).publish_state(cv14);
int cv15 = (bytes[31] << 8) | bytes[32];
id(cellv15).publish_state(cv15);
int cv16 = (bytes[33] << 8) | bytes[34];
id(cellv16).publish_state(cv16);
int cv17 = (bytes[35] << 8) | bytes[36];
id(cellv17).publish_state(cv17);
int cv18 = (bytes[37] << 8) | bytes[38];
id(cellv18).publish_state(cv18);
int cv19 = (bytes[39] << 8) | bytes[40];
id(cellv19).publish_state(cv19);
int cv20 = (bytes[41] << 8) | bytes[42];
id(cellv20).publish_state(cv20);
int cv21 = (bytes[43] << 8) | bytes[44];
id(cellv21).publish_state(cv21);
int cv22 = (bytes[45] << 8) | bytes[46];
id(cellv22).publish_state(cv22);
int cv23 = (bytes[47] << 8) | bytes[48];
id(cellv23).publish_state(cv23);
int cv24 = (bytes[49] << 8) | bytes[50];
id(cellv24).publish_state(cv24);
int t1 = ((((bytes[51] << 8) | bytes[52]) - 40) * 9/5) + 32;
id(temp1).publish_state(t1);
int t2 = ((((bytes[53] << 8) | bytes[54]) - 40) * 9/5) + 32;
id(temp2).publish_state(t2);
int t3 = ((((bytes[55] << 8) | bytes[56]) - 40) * 9/5) + 32;
id(temp3).publish_state(t3);
int t4 = ((((bytes[57] << 8) | bytes[58]) - 40) * 9/5) + 32;
id(temp4).publish_state(t4);
modbus:
- id: modbus0
uart_id: uart_0
send_wait_time: 1000ms
disable_crc: true
flow_control_pin: 4
# int at = ((((bytes[73] << 8) | bytes[74]) - 40) * 9/5) + 32;
# id(ambienttemp).publish_state(at);
modbus_controller:
- id: bms
address: 0x81
modbus_id: modbus0
command_throttle: 5000ms
update_interval: 2s
setup_priority: -20
name: "Voltage" # 0x38 register
filters:
- multiply: 0.1
accuracy_decimals: 2
unit_of_measurement: "V"
state_class: measurement
icon: mdi:meter-electric
device_class: Voltage
name: Current # 0x39 register
filters:
- multiply: 0.1
accuracy_decimals: 1
unit_of_measurement: "A"
device_class: current
name: SOC # 0x3A register
filters:
- multiply: 0.1
unit_of_measurement: "%"
accuracy_decimals: 0
icon: mdi:battery
device_class: battery
name: "Cell Volt Max" # 0x3E register
filters:
- multiply: 0.001
accuracy_decimals: 3
icon: mdi:sine-wave
name: "Cell Index Max" # 0x3F register
name: "Cell Volt Min" # 0x40 register
filters:
- multiply: 0.001
icon: mdi:sine-wave
name: "Cell Index Min" # 0x41 register
name: "Cell Volt delta" # 0x42 register
filters:
- multiply: 0.001
icon: mdi:sine-wave
name: "Battery Remain Capacity" # 0x4B register
#filters:
# - multiply: 0.001
unit_of_measurement: "Ah"
icon: mdi:battery
name: "Battery Num Cycles" # 0x4C register
icon: mdi:battery-sync
name: "Balancing State [0:off,1:pas,2:act]" # 0x4D register
icon: mdi:power-plug
name: "Balance Current" # 0x4E register
filters:
- multiply: 0.001
unit_of_measurement: "mA" # guessing
icon: mdi:scale-unbalanced
#0x4F-0x51 equilibrium position
name: "Charging Mos Status [0:off|1:on]" # 0x52 register
name: "Discharging Mos Status [0:off|1:on]" # 0x53 register
name: "Cell Volt Avg" # 0x57 register
filters:
- multiply: 0.001
icon: mdi:sine-wave
name: "Power" # 0x58 register
# filters:
# - multiply: 0.001
unit_of_measurement: "W"
icon: mdi:flash
name: "Energy" # 0x59 register
# filters:
# - multiply: 0.001
unit_of_measurement: "Wh"
name: "MOS Temp" # 0x5A register
unit_of_measurement: "f"
device_class: temperature
icon: mdi:thermometer
# - platform: template
# id: ambienttemp
# name: "Ambient Temp" # 0x5B register
# # filters:
# # - multiply: 0.001
# accuracy_decimals: 1
# unit_of_measurement: "f"
# # device_class: temperature
# state_class: measurement
# icon: mdi:thermometer
name: "Temperature 1" # 0x30 register
name: "Temperature 2" # 0x32 register
name: "Temperature 3" # 0x34 register
name: "Temperature 4" # 0x36 register
name: "Cell Volt 01" # 0x00 register
filters:
- multiply: 0.001
name: "Cell Volt 02" # 0x02 register
filters:
- multiply: 0.001
name: "Cell Volt 03" # 0x04 register
filters:
- multiply: 0.001
name: "Cell Volt 04" # 0x06 register
filters:
- multiply: 0.001
name: "Cell Volt 05" # 0x08 register
filters:
- multiply: 0.001
name: "Cell Volt 06" # 0x0A register
filters:
- multiply: 0.001
name: "Cell Volt 07" # 0x0C register
filters:
- multiply: 0.001
name: "Cell Volt 08" # 0x0E register
filters:
- multiply: 0.001
name: "Cell Volt 09" # 0x10 register
filters:
- multiply: 0.001
name: "Cell Volt 10" # 0x12 register
filters:
- multiply: 0.001
name: "Cell Volt 11" # 0x14 register
filters:
- multiply: 0.001
name: "Cell Volt 12" # 0x16 register
filters:
- multiply: 0.001
name: "Cell Volt 13" # 0x18 register
filters:
- multiply: 0.001
name: "Cell Volt 14" # 0x1A register
filters:
- multiply: 0.001
name: "Cell Volt 15" # 0x1C register
filters:
- multiply: 0.001
name: "Cell Volt 16" # 0x1E register
filters:
- multiply: 0.001
name: "Cell Volt 17" # 0x20 register
filters:
- multiply: 0.001
name: "Cell Volt 18" # 0x22 register
filters:
- multiply: 0.001
name: "Cell Volt 19" # 0x24 register
filters:
- multiply: 0.001
name: "Cell Volt 20" # 0x26 register
filters:
- multiply: 0.001
name: "Cell Volt 21" # 0x28 register
filters:
- multiply: 0.001
name: "Cell Volt 22" # 0x2A register
filters:
- multiply: 0.001
name: "Cell Volt 23" # 0x2C register
filters:
- multiply: 0.001
name: "Cell Volt 24" # 0x2E register
filters:
- multiply: 0.001
# Get Cell Voltages + temp 0x00 - 0x37 (56 bytes /2 = 28 registers [0x1C]) ) | total bytes = 56 + 5 = 61 Bytes
- platform: modbus_controller
modbus_controller_id: bms
custom_command: [0x81, 0x03, 0x00, 0x00, 0x00, 0x1C]
# 0x38 first register to read, 0xB = 11 register count (27 byte response [1Byte = ADDR, 1Byte = CMD, 1Byte = Length, 2Bytes = CRC, reminder = register count x 2]) - ORIG
custom_command: [0x81, 0x03, 0x00, 0x38, 0x00, 0x0B]
custom_command: [0x81, 0x03, 0x00, 0x4B, 0x00, 0x04]
custom_command: [0x81, 0x03, 0x00, 0x52, 0x00, 0x09]
Nice job!!
Thanks, great work.
Greetings.
Looks like you cracked it, great.
Do you still require the excel file?? Sorry, I donāt visit here to often.
Here is the complete file:
I have just tested it and it works!! Thank you so much!!
As for temperature in Fahrenheit to switch to Celcius I have to change this formula?:
Thanks for figuring this all out. If I just could somehow get you a coffee or something remotelyā¦
Edit:
Did you get the right battery temperatures? I only get -40, the same as you.
