Issue with a lambda using the value of a select
Hi all,
I have the following select with an action when the value changes:
    name: Schedule 2 Program
    options:
     - "Standard - 2300 RPM"
     - "Solar Heating - 40 GPM"
     - "Cleaner - 2650 RPM"
     - "Freeze Protect - 1250 RPM"
    initial_option: "Standard - 2300 RPM"
    optimistic: true
    on_value:
      then:
      - lambda: |-
         auto program = i + 1;
         id(pentairpump).commandLocalProgram(program);
Now, this by itself works as defined.
However, I want to use the value (index) of this select elsewhere to run the same action and created the following lambda in a script (note: took out some parts
  - id: egg_timer_check
    then:
      lambda: |-
        if (id(egg_timer_enabled).state)
            auto index = id(egg_timer_program).active_index();
            auto program = index + 1;
            id(pentairpump).run();
That however gives me the following compiler error:
/config/esphome-pool-heater.yaml: In lambda function:
/config/esphome-pool-heater.yaml:810:32: error: no match for 'operator+' (operand types are 'esphome::optional<unsigned int>' and 'int')
In file included from src/esphome/core/entity_base.h:5,
                 from src/esphome/components/binary_sensor/binary_sensor.h:4,
                 from src/esphome/core/controller.h:5,
                 from src/esphome/components/api/api_server.h:11,
                 from src/esphome/components/api/api_connection.h:8,
                 from src/esphome.h:3,
                 from src/main.cpp:3:
src/esphome/core/string_ref.h:118:20: note: candidate: 'std::__cxx11::string esphome::operator+(const char*, const esphome::StringRef&)'
 inline std::string operator+(const char *lhs, const StringRef &rhs) {
src/esphome/core/string_ref.h:118:20: note:   no known conversion for argument 1 from 'esphome::optional<unsigned int>' to 'const char*'
src/esphome/core/string_ref.h:124:20: note: candidate: 'std::__cxx11::string esphome::operator+(const esphome::StringRef&, const char*)'
 inline std::string operator+(const StringRef &lhs, const char *rhs) {
src/esphome/core/string_ref.h:124:20: note:   no known conversion for argument 1 from 'esphome::optional<unsigned int>' to 'const esphome::StringRef&'
*** [.pioenvs/esphome-pool-heater/src/main.cpp.o] Error 1
========================== [FAILED] Took 4.56 seconds ==========================
Anybody who can help me out here?
Thanks,
B.
Maybe if you post all the yaml instead of just the bits you think are relevant…
Hi Daryl,
as it’s a meaty piece of code, I thought of only adding the code that’s giving me problems… But here’s the entire bunch:
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  level: DEBUG
  logs:
    text_sensor: ERROR
# Enable Home Assistant API
api:
ota:
  platform: esphome
time:
  - platform: sntp
    timezone: America/New_York
    servers:
      - pfsense.deprez.biz
      - 0.pool.ntp.org
      - 1.pool.ntp.org
    on_time_sync:
      - globals.set:
          value: "true"
    on_time:
      - seconds: /15
        then:
          - script.execute: ichlor_on_off_script
          - script.execute: pump_schedule_check
wifi:
  ssid: "REDACTED"
  password: "REDACTED"
  manual_ip:
    static_ip: 172.16.10.138
    gateway: 172.16.10.1
    subnet: 255.255.255.0
    dns1: 172.16.10.15
  domain: .REDACTED
  ap:
    ssid: "REDACTED"
captive_portal:
external_components:
  - source: github://bdeprez/Pool_Automation@main
    # https://github.com/bdeprez/Pool_Automation/tree/main
    components: [pentair_intelliflo]
    refresh: 0s
uart:
  tx_pin: GPIO17
  rx_pin: GPIO18
  baud_rate: 9600
pentair_intelliflo:
web_server:
  port: 80
  version: 3
  auth:
    username: "REDACTED"
  sorting_groups:
    - id: sorting_group_temperatures
      sorting_weight: -10
    - id: sorting_group_heating
      sorting_weight: -9
    - id: sorting_group_pump_status
      sorting_weight: -20
    - id: sorting_group_pump_schedules
      name: "Pump Schedules"
      sorting_weight: -19
    - id: sorting_group_pump_eggtimer
      name: "Pump Egg Timer"
      sorting_weight: -18
    - id: sorting_group_pump_freezeprotect
      name: "Pump Freeze Protect"
      sorting_weight: -17
    - id: sorting_group_ichlor
      sorting_weight: -15
    - id: sorting_group_waterfall
      sorting_weight: -5
    - id: sorting_group_light
      sorting_weight: -4
globals:
  - id: time_synced
    type: bool
    restore_value: no
    initial_value: "false"
  # pump mode: 0: inactive, 1: sched 1, 2: sched 2, 3: eggtimer, 4: freezeprotect, (9:always_on)
  - id: pump_mode
    type: int
    restore_value: yes
    initial_value: "0"
  # to count timestamp when the pump was started
  - id: pump_running_timestamp
    type: long int
    restore_value: no
    initial_value: "0"
  # to count timestamp when the pump has been stopped
  - id: pump_stopped_timestamp
    type: long int
    restore_value: no
    initial_value: "0"
  - id: egg_timer_start_timestamp
    type: long int
    restore_value: no
    initial_value: "0"
  - id: pump_running_for
    type: long int
    restore_value: no
    initial_value: "0"
  - id: pump_stopped_for
    type: long int
    restore_value: no
    initial_value: "0"
  - id: egg_timer_check_script_result
    type: bool
    restore_value: no
  - id: freeze_protect_check_script_result
    type: bool
    restore_value: no
  - id: schedule_1_check_script_result
    type: bool
    restore_value: no
  - id: schedule_2_check_script_result
    type: bool
    restore_value: no
  - id: schedule_1_current_program
    type: int
    restore_value: yes
    initial_value: "1"
  - id: schedule_1_new_program
    type: int
    restore_value: yes
    initial_value: "1"
  - id: schedule_2_current_program
    type: int
    restore_value: yes
    initial_value: "1"
  - id: schedule_2_new_program
    type: int
    restore_value: yes
    initial_value: "1"
  - id: egg_timer_current_program
    type: int
    restore_value: yes
    initial_value: "3"
  - id: egg_timer_new_program
    type: int
    restore_value: yes
    initial_value: "3"
  - id: freeze_protect_current_program
    type: int
    restore_value: yes
    initial_value: "4"
  - id: freeze_protect_new_program
    type: int
    restore_value: yes
    initial_value: "4"
  - platform: wifi_signal
    update_interval: 60s
    entity_category: diagnostic
  # Reports the WiFi signal strength in %
  - platform: copy
    source_id: wifi_signal_db
    name: "WiFi Strength"
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: "%"
#  - platform: pentair_intelliflo
#    power:
#      id: pump_power
#      name: "Power"
#      web_server:
#        sorting_group_id: sorting_group_pump_status
#        sorting_weight: 4
#    rpm:
#      id: pump_rpm
#      name: "RPM"
#      unit_of_measurement: 'RPM'
#      web_server:
#        sorting_weight: 5
#    flow:
#      id: pump_gpm
#      name: "GPM"
#      unit_of_measurement: gal/min
#      web_server:
#        sorting_weight: 6
# !!! TEMP !!! POOL & ROOF TEMP - removed for testing purposes
  #Pool sensor voltages
#  - platform: ads1115
#    multiplexer: 'A0_GND'
#    gain: 4.096
#    update_interval: 30s
#    id: pool_voltage
#    name: "Pool Sensor Voltage"
#    multiplexer: 'A1_GND'
#    gain: 4.096
#    id: roof_voltage
#    name: "Roof Sensor Voltage"
  #Pool sensor resistance
#  - platform: resistance
#    id: pool_resistance
#    sensor: pool_voltage
#    configuration: DOWNSTREAM
#    resistor: 9.6kOhm
#    name: Pool Resistance
#    id: roof_resistance
#    sensor: roof_voltage
#    resistor: 9.6kOhm
#    name: Roof Resistance
  #Pool sensor temperatures
  # https://esphome.io/components/sensor/ntc.html#ntc-sensor
#  - platform: ntc
#    id: pool_temp_c
#    name: Pool Temperature C
#    sensor: pool_resistance
#    calibration:
#      - 10.0kOhm -> 25°C
#      - 32.648kOhm -> 0°C
#      - 15.711kOhm -> 15°C
#    web_server:
#      sorting_group_id: sorting_group_temperatures
#      sorting_weight: 10
#  - platform: copy
#    source_id: pool_temp_c
#    id: pool_temp_f
#    name: Pool Temperature F
#    filters:
#      - lambda: return (x * 9/5) + 32;
#    unit_of_measurement: °F
#    web_server:
#      sorting_weight: 12
#  - platform: ntc
#    id: roof_temp_c
#    name: Roof Temperature C
#    sensor: roof_resistance
#    calibration:
#    web_server:
#      sorting_weight: 11
#  - platform: copy
#    source_id: roof_temp_c
#    id: roof_temp_f
#    name: Roof Temperature F
#    filters:
#    web_server:
#      sorting_weight: 13
number:
  # Pool Heating - target temperature
    name: Target Temperature
    optimistic: True
    restore_value: True
    initial_value: 30
    update_interval: never
    min_value: 25
    max_value: 35
    step: 1
    device_class: temperature
    unit_of_measurement: °C
    icon: mdi:coolant-temperature
    mode: SLIDER
    web_server:
      sorting_group_id: sorting_group_heating
      sorting_weight: 6
  # Home Assistant - Outdoor Temperature
  - platform: homeassistant
    entity_id: sensor.tempest_ws_feels_like
    entity_id: sensor.tempest_ws_temperature
  # Freeze Protect  - Start temperature
    name: Freeze Protect Temp
    optimistic: True
    restore_value: True
    initial_value: 30
    min_value: 0
    max_value: 5
    step: 0.1
    mode: SLIDER
    web_server:
      sorting_group_id: sorting_group_pump_freezeprotect
      sorting_weight: 2
  # EGG TIMER duration
    name: Egg Timer Duration
    min_value: 15
    max_value: 300
    step: 30
    initial_value: 60
    optimistic: True
    unit_of_measurement: min
    mode: SLIDER
    web_server:
      sorting_group_id: sorting_group_pump_eggtimer
      sorting_weight: 2
  # !!! TEMP !!! POOL & ROOF TEMP - added for testing purposes
    min_value: 25
    max_value: 35
    step: 1
    initial_value: 25
    optimistic: True
    mode: SLIDER
    web_server:
      sorting_weight: 1
    min_value: 25
    max_value: 35
    step: 1
    initial_value: 25
    optimistic: True
    mode: SLIDER
    web_server:
      sorting_weight: 2
###DATETIME TIMES###
datetime:
    type: time
    name: Schedule 1 Start Time
    optimistic: yes
    initial_value: "08:00:00"
    restore_value: true
    web_server:
      sorting_group_id: sorting_group_pump_schedules
      sorting_weight: 2
    type: time
    name: Schedule 1 End Time
    optimistic: yes
    initial_value: "18:00:00"
    restore_value: true
    web_server:
      sorting_weight: 3
    type: time
    name: Schedule 2 Start Time
    optimistic: yes
    restore_value: true
    web_server:
      sorting_weight: 6
    type: time
    name: Schedule 2 End Time
    optimistic: yes
    restore_value: true
    web_server:
      sorting_weight: 7
    type: time
    name: Waterfall Start Time
    optimistic: yes
    restore_value: true
    web_server:
      sorting_group_id: sorting_group_waterfall
      sorting_weight: 4
    type: time
    name: Waterfall End Time
    optimistic: yes
    initial_value: "08:05:00"
    restore_value: true
    web_server:
      sorting_weight: 5
button:
# !!! TEMP !!! added only for testing purposes
    name: "Pump Run Button"
    on_press:
      then:
        if:
          condition:
            - binary_sensor.is_on: pump_running_status
          then:
            lambda: |-
              id(pump_running_status).publish_state(false);
          else:
            lambda: |-
              id(pump_running_status).publish_state(true);
  - platform: restart
    entity_category: config
binary_sensor:
#    running:
#      name: "Pump Running"
#      id: pump_running_status
#      web_server:
#        sorting_weight: 2
  - platform: template ## replace with above on PRD ##
    device_class: running
    on_state:
      then:
        - if:
            condition:
            then:
              lambda: |-
                id(pump_running_timestamp) = id(sntp_time).now().timestamp;
                ESP_LOGD("TEST", "Pump running timestamp set to: ", id(pump_running_timestamp));
            else:
              lambda: |-
                id(pump_stopped_timestamp) = id(sntp_time).now().timestamp;
                ESP_LOGD("TEST", "Pump stopped timestamp set to: ", id(pump_stopped_timestamp));
    web_server:
      sorting_weight: 2
  - platform: copy
    source_id: pump_running_status
switch:
  # Pump enabled/disabled
    restore_mode: RESTORE_DEFAULT_ON
    optimistic: True
    web_server:
      sorting_weight: 1
    on_turn_on:
      then:
      - lambda: |-
#      - text_sensor.template.publish:
#          id: last_action
#          state: "Pump ON"
    on_turn_off:
      then:
      - lambda: |-
          id(pentairpump).stop();
#          id: last_action
#          state: "Pump OFF"
  # Schedule 1 enabled
    name: "Schedule 1 Enabled"
    optimistic: True
    web_server:
      sorting_weight: 1
  # Schedule 2 enabled
    name: "Schedule 2 Enabled"
    restore_mode: RESTORE_DEFAULT_OFF
    optimistic: True
    web_server:
      sorting_weight: 5
  # Egg Timer enabled
    name: "Egg Timer Enabled"
    optimistic: True
    web_server:
      sorting_weight: 1
  # Freeze Protect enabled
    name: "Freeze Protect Enabled"
    optimistic: True
    web_server:
      sorting_weight: 11
  # iChlor switches
  # !!! TEMP !!! added for testing purposes
#    on_turn_on:
#          id: last_action
#          state: "iChlor ON"
#    on_turn_off:
#          id: last_action
#          state: "iChlor OFF"
    optimistic: True
    web_server:
      sorting_group_id: sorting_group_ichlor
      sorting_weight: 9
  # !!! TEMP !!! commented for testing purposes
#  - platform: gpio
#    pin:
#      number: GPIO45
#      ignore_strapping_warning: true
#    id: relay5
#    name: iChlor L2
#    internal: True
#  - platform: gpio
#    pin:
#      number: GPIO46
#    id: relay6
#    name: iChlor L1
#    internal: True
#    on_turn_on:
#          id: last_action
#    on_turn_off:
#          id: last_action
    optimistic: True
    web_server:
      sorting_weight: 10
  # Switch to enable / disable heating
    optimistic: True
    web_server:
      sorting_weight: 5
  # Heater Relay Switch
  - platform: gpio
    pin: GPIO2
#    on_turn_on:
#      then:
#            id: last_action
#            state: "Heater Valve OPENED"
#    on_turn_off:
#      then:
#            id: last_action
#            state: "Heater Valve CLOSED"
    web_server:
      sorting_weight: 7
  # Waterfall Relay Switch
  # !!! TEMP !!! removed for testing purposes
#  - platform: gpio
#    pin: GPIO41
#    on_turn_on:
#      then:
#            id: last_action
#            state: "Waterfall Valve OPENED"
#    on_turn_off:
#      then:
#            id: last_action
#            state: "Waterfall Valve CLOSED"
    optimistic: True ### REMOVE ON PROD ###
    web_server:
      sorting_weight: 2
  # Switch to enable / disable waterfall
    optimistic: True
    web_server:
      sorting_weight: 1
  # Waterfall Schedule enabled
    name: "Watefall Schedule Enabled"
    optimistic: True
    web_server:
      sorting_weight: 3
    name: "Watefall Always On"
    optimistic: True
    web_server:
      sorting_weight: 6
  # Light Relay Switch
#  - platform: gpio
#    pin: GPIO42
    on_turn_on:
      then:
            state: "Light ON"
    on_turn_off:
      then:
            state: "Light OFF"
    web_server:
      sorting_group_id: sorting_group_light
      sorting_weight: 10
select:
  # To select Pump program
    name: Schedule 1 Program
    options:
     - "Freeze Protect - 1000 RPM"
    restore_value: True
    optimistic: true
    on_value:
      then:
      - lambda: |-
    web_server:
      sorting_weight: 4
    options:
    restore_value: True
    optimistic: true
#    on_value:
#      then:
#      - lambda: |-
#         auto program = i + 1;
#         id(pentairpump).commandLocalProgram(program);
    web_server:
      sorting_weight: 8
  # To select Timer program
    name: Egg Timer Program
    options:
    initial_option: "Cleaner - 2650 RPM"
    restore_value: True
    optimistic: true
    web_server:
      sorting_weight: 3
  # To select Freeze protect program
    name: Freeze Protect Program
    options:
    initial_option: "Freeze Protect - 1250 RPM"
    restore_value: True
    optimistic: true
    web_server:
      sorting_weight: 3
text_sensor:
  - platform: version
  - platform: wifi_info
    ip_address:
    ssid:
    mac_address:
  # https://esphome.io/components/text_sensor/template.html
    icon: mdi:message
    lambda: return {"System Started"};
    icon: mdi:message
    lambda: |-
      switch(id(pump_mode)) {
        case 0: return std::string("Inactive");
        case 1: return std::string("Schedule 1");
        case 2: return std::string("Schedule 2");
        case 3: return std::string("Egg Timer");
        case 4: return std::string("Freeze Protect");
        //case 9: return std::string("Always On");
        default: return std::string("No Known Mode");
    update_interval: 1s
    web_server:
      sorting_weight: 3
script:
  - id: pump_schedule_check
    then:
      lambda: |-
        if (id(time_synced))
            switch (id(pump_mode))
                // (inactive)
                case 0:
                  if (id(pump_enabled).state)
                      id(egg_timer_check).execute();
                  else
                //run  egg_timer_check
                //if schedule_1_enabled
                //  then run schedule_1_check
    then:
      lambda: |-
    then:
      lambda: |-
        if (id(schedule_1_enabled).state)
            auto current_time = (id(sntp_time).now().hour * 3600) + (id(sntp_time).now().minute * 00) + (id(sntp_time).now().second);
            auto schedule_start_time_seconds = (id(pump_sched_1_start).hour * 3600) + (id(pump_sched_1_start).minute * 60) + id(pump_sched_1_start).second;
            auto schedule_end_time_seconds = (id(pump_sched_1_end).hour * 3600) + (id(pump_sched_1_end).minute * 60) + id(pump_sched_1_end).second;
            if (current_time >= schedule_start_time_seconds < schedule_end_time_seconds)
                id(pump_mode) = 1;
    then:
      lambda: |-
        if (id(schedule_2_enabled).state)
            auto current_time = id(sntp_time).now().timestamp;
            auto schedule_start_time_seconds = (id(pump_sched_2_start).hour * 3600) + (id(pump_sched_2_start).minute * 60) + id(pump_sched_2_start).second;
            auto schedule_end_time_seconds = (id(pump_sched_2_end).hour * 3600) + (id(pump_sched_2_end).minute * 60) + id(pump_sched_2_end).second;
                id(pump_mode) = 2;
#  - id: freeze_protect_script
#    then:
#      lambda: |-
  - id: ichlor_on_off_script # Triggered every minute from Time
    then:
      lambda: |-
        //if (id(homeassistant_time).now().timestamp.is_valid())
        if (id(sntp_time).now().is_valid())
            // get current time
            // check if pump is running
            if (id(pump_running_status).state == true)
              // pump is running
                if (id(iChlor_relay).state == false)
                  // iChlor is off
                    id(pump_running_for) = difftime((current_time), id(pump_running_timestamp));
                    ESP_LOGD("TEST", "Pump running for: %d", id(pump_running_for));
                    if (id(pump_running_for) >= 60)
                        id(iChlor_relay).turn_on();
                        ESP_LOGD("TEST", "iChlor turned on");
              // pump is not running
              else
                if (id(iChlor_relay).state == true)
                  // iChlor is on
                    id(pump_stopped_for) = difftime((current_time), id(pump_stopped_timestamp));
                    ESP_LOGD("TEST", "Pump stopped for: %d", id(pump_stopped_for));
                    if (id(pump_stopped_for) >= 60)
                        id(iChlor_relay).turn_off();
                        ESP_LOGD("TEST", "iChlor turned off");
Note: this version of the code is for testing purposes as I cannot use the target device without taking the current systems out without rewiring. So I’m simulating a number of sensors with manual workarounds for testing.
Thanks!
B.
because you need .active_index().value() + 1
Look at the documentation example:
auto index = id(my_select).active_index();
if (index.has_value()) {
  ESP_LOGI("main", "Option at index %d is active", index.value());
} else {
  ESP_LOGI("main", "No option is active");
Brilliant, I totally overlooked that - thank you @Karosm
Sorry for my delayed response - have been busy work-wise so hadn’t gotten around to work on this till now.
B.
No problem. I’m pleased to get any response, sooner or later. Not always the case…
Sorry isnt going to cut it around here for me, sir!! Next time your going to be late, we expect you to show up with some breakfast sandwiches or some donuts because we can’t eat “sorry’s” “traffic was bad”, etc excuses!!! Dang rookies!! ; )
Jk dude… Did you happen to mention what it is your making? Im just curious.
As my recent pool controller (the Pentair Intelliconnect) which I installed in May of 2020 died, the pool guys’ only suggestion was to upgrade to the more expensive ones and I was not going to shell out 2.3K dollars for something that’s pretty simple, really.
So, with the experience of my previous adventure (see: How I added a Hayward solar pool control to HA via ESPhome) I decided to build one myself.
I’ve so far been able to create a setup that controls the pump, pool solar heating, waterfall and the light. Currently the chlorinator is only partially integrated in where I can power it on/off and it’s still relying on the RS485 connection to the pump to know if there’s flow. I am struggling massively to create the code to fully integrate so I can update the output percentage.
I’m working on a write-up of what I accomplished so far, hoping somebody may be interested in helping out with the chlorinator. Write-up now published New Pentair pool automation setup – full write-up
Well that’s no surprise! I bet he was kind enough to let you pay him to so it for you too lol.
FYI back when i worked in landscaping and construction in general, things like pools or luxury cars were signs to us that the price was gonna get jacked up when it didnt look like people would miss an extra 500$ or so. Thats capitalism for ya though…
In the future you shouod borrow someone’s hooptie Ford Taurus and park it in the driveway and pretend your just house sitting and need to fix something you messed up or some similar story if you dont want contractors to tack on an extra 25% just because they think you wont want to negotiate the difference, or do what what you want, its just a tip.
Im busy for a couple more hours but, ill check it out and see if i can help ya out! You’re still at the same address, right? Just want to verify where i need to send my bill for tech support!
