I’m new to HA, so I apologize in advance if I do not give all information upfront. I’m migrated all of my ST zigbee equipment off of my ST hub and directly into HA and onto the SkyConnect last weekend. A few times over the week, the ZHA integration was stuck initializing… I didn’t have time to troubleshoot, so I just rebooted HA. This resolved the issue a few times, but now it simply will not come back up. I’ve flashed the SkyConnect to the latest firmware but still, no joy…
Using the debugging option in ZHA, i get the following:
2023-12-23 09:30:16.628 ERROR (MainThread) [bellows.ezsp] NCP entered failed state. Requesting APP controller restart
2023-12-23 09:30:16.855 ERROR (MainThread) [zigpy.zcl] [0xB92E:1:0x0b04] Traceback (most recent call last):
File “/usr/local/lib/python3.11/site-packages/zigpy/zcl/init.py”, line 411, in reply
return await self._endpoint.reply(
File “/usr/local/lib/python3.11/site-packages/zigpy/endpoint.py”, line 278, in reply
return await self.device.reply(
File “/usr/local/lib/python3.11/site-packages/zigpy/device.py”, line 474, in reply
return await self.request(
File “/usr/local/lib/python3.11/site-packages/zigpy/device.py”, line 299, in request
await self._application.request(
File “/usr/local/lib/python3.11/site-packages/zigpy/application.py”, line 829, in request
await self.send_packet(
File “/usr/local/lib/python3.11/site-packages/bellows/zigbee/application.py”, line 762, in send_packet
status, _ = await self._ezsp.sendUnicast(
AttributeError: ‘NoneType’ object has no attribute ‘sendUnicast’
2023-12-23 09:30:16.856 ERROR (MainThread) [zigpy.zcl] [0xB92E:1:0x0b04] Traceback (most recent call last):
2023-12-23 09:30:16.857 ERROR (MainThread) [zigpy.zcl] [0x0113:1:0x0b04] Traceback (most recent call last):
2023-12-23 09:30:16.859 ERROR (MainThread) [zigpy.zcl] [0xE25B:1:0x0019] Traceback (most recent call last):
File “/usr/local/lib/python3.11/site-packages/zigpy/zcl/clusters/general.py”, line 2187, in _handle_cluster_request
await self._handle_query_next_image(
File “/usr/local/lib/python3.11/site-packages/zigpy/zcl/clusters/general.py”, line 2259, in _handle_query_next_image
await self.query_next_image_response(
2023-12-23 09:30:16.860 ERROR (MainThread) [zigpy.zcl] [0xB92E:1:0x0b04] Traceback (most recent call last):
2023-12-23 09:30:16.861 ERROR (MainThread) [zigpy.zcl] [0x9465:1:0x0b04] Traceback (most recent call last):
2023-12-23 09:30:16.866 ERROR (MainThread) [zigpy.zcl] [0x9465:1:0x0b04] Traceback (most recent call last):
2023-12-23 09:30:16.867 ERROR (MainThread) [zigpy.zcl] [0x9465:1:0x0b04] Traceback (most recent call last):
2023-12-23 09:30:16.868 WARNING (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xA03E:11:0x0006]: ‘async_initialize’ stage failed: ‘NoneType’ object has no attribute ‘sendUnicast’
File “/usr/src/homeassistant/homeassistant/components/zha/core/helpers.py”, line 338, in wrapper
return await func(cluster_handler, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/init.py”, line 389, in async_initialize
await self._get_attributes(
File “/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/init.py”, line 491, in _get_attributes
read, _ = await self.cluster.read_attributes(
File “/usr/local/lib/python3.11/site-packages/zigpy/zcl/init.py”, line 524, in read_attributes
result = await self.read_attributes_raw(to_read, manufacturer=manufacturer)
File “/usr/local/lib/python3.11/site-packages/zigpy/zcl/init.py”, line 377, in request
return await self._endpoint.request(
File “/usr/local/lib/python3.11/site-packages/zigpy/endpoint.py”, line 253, in request
return await self.device.request(
2023-12-23 09:30:16.871 WARNING (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xA03E:11:0x0300]: ‘async_initialize’ stage failed: ‘NoneType’ object has no attribute ‘sendUnicast’
2023-12-23 09:30:16.873 WARNING (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xA03E:11:0x0008]: ‘async_initialize’ stage failed: ‘NoneType’ object has no attribute ‘sendUnicast’
2023-12-23 09:30:16.876 WARNING (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0xE25B:1:0x0001]: ‘async_initialize’ stage failed: ‘NoneType’ object has no attribute ‘setExtendedTimeout’
File “/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/init.py”, line 400, in async_initialize
await ch_specific_init(from_cache=from_cache)
File “/usr/local/lib/python3.11/site-packages/bellows/zigbee/application.py”, line 750, in send_packet
await self._ezsp.setExtendedTimeout(device.ieee, True)
AttributeError: ‘NoneType’ object has no attribute ‘setExtendedTimeout’
2023-12-23 09:30:21.183 WARNING (MainThread) [homeassistant.components.zha.core.cluster_handlers] [0x141A:11:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), ControllerError(‘ApplicationController is not running’), ControllerError(‘ApplicationController is not running’), ControllerError(‘ApplicationController is not running’)]
