I am adding a Schlage Lock to my network. It was working fine on SmartThings. I removed it from SmartThings and tried to add to HA.
I added using “Add Secure Node” I have a network_key configured so this should work.
It got added at first as “Unknow Device” but after a restart it showed up as “Schlage FE599GR Wireless Door Lock”.
I renamed to “Entry Lock” and that worked fine.
But when I use the UI to lock/unlock, nothing happens. When I manually lock/unlock status is not reflected in HA.
So I tried to “Remove Node” to see if adding it back in work work.
I selected Remove Node and put the lock in include/exclude mode.
Nothing changed, the node remained.
So I tried “Remove Failed Node”, again no change.
So I am now stuck with a device which may or may not be included and no real way to tell.
What should I do to repair this?
Edit: I might have made matters worse. I decided to try to include it again. Now I have the lock listed twice but neither works.
How do I remove remove these?
How do I get this lock working? I followed the post here
But that is how I got in the state I am in.
anyone have this lock and some advice?
