I am using the Virtual Machine integrated Image of HoAss. Worked really fine over months. Now my hypervisor had a glitch and therefore the VM with HA was shutdown unclean.
Unfortunately, I am having issues with HA now. My Grafana instance will not start. I discovered the following error in UI:
Going further and checking the logs brought me to this:
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:217
Integration: Recorder (documentation, issues)
First occurred: 07:35:08 (1 occurrences)
Last logged: 07:35:08
The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
I can only see the supervisor logs, on all other logs (host, dns, etc.) I am getting “Forbidden: 403”, even though I am logged in as administrator.
May I assume something is really broken here? Is there a chance to recover?
I took several backups (HA internally) recently but I never tried to restore. Is the restore for the VM image documented somewhere? How about the add-ons like Grafana?
Thanks for suggestions!
/KNEBB
