I seem to keep falling into different issues with different switches but also trying to use ZHA in just Home Assistant and trying to come away from Smartlife App, so please bare with me on this as I keep getting different outcomes and some seem better but still not correct.
But then go to worse a day or so later or they do not work as they should. Due to one of the switches being a No live wire need which in the UK we do not have any No Neutral Wire in the properties. I have now added a capacitor in to make sure that is done right now!
Then Im told you cannot have an RGB colour Bulb when connected to a switch which is what I want and was then informed the best way is to use Hue Bulbs to do this but not fully sure if that will also correct on my needs to be more local rather than using other servers to run things.
Why the ZHA approach?
So I changed over to this new Switch a few days ago called a Yagusmart WiFi Smart Wall Light Switch, No Neutral Wire Required, No Hub Required, Compatible with Alexa and Google Home, APP Remote Control, Timing Functions, Voice Control(2 Gang-Black) [Energy Class A++] with AISIRER Alexa Smart Bulb WiFi Light Bulbs E27 Screw, 2 Pack, 10W 1000LM, App or Voice Control, 90W Dimmable White and RGBCW Colour Changing Light Bulb, Works with Alexa, Google Home, No Hub Required
and everything seemed to be working great with no issues at all the bulbs would come on and off from the switch itself as well as in HA then after me messing around with Automation and things.
I noticed the outside light started to come on whenever it felt like it and this was after I used a method of using automation to make a switch turn strip lights on and off I did that.
Then realised it needed to be done the opposite way around and when the button was pressed need it to have turned to on from Off which again was fine and works 100% in HA
But the Switch buttons a day after stopped working altogether, the lights come on and off when I used HA for lights and also the Automation all work right with the Sensors just not sure what has happened so I’m unable to use the switch buttons at all now.
I have also taken the sensors out of using Smartlife and just using HA now so Im now only using HA for the setup.
I then thought maybe I need to reset the switch a repair it in Smartlife as it’s not compatible I dont t think only using HA unless someone knows more about this to help me get it fully into HA be great, but any how I was unable to put it into pairing mode as like I said the buttons have stopped working.
So could it be a faulty Switch that needs to be sent back or a software glitch stopping me from pressing any buttons? I have not tried to turn the main power off yet to see if that will reset the switch as that will be the last thing I do before sending it back.
Hard for me to fully explain this issue as I have done many different things to get it working! the other Switch I tried was a MOES Tuya ZigBee Smart Touch Switch, which Requires Tuya ZigBee Hub, No Neutral Wire No Capacitor Needed, also Works with L & N wire, Compatible with Smart Life Tuya App Alexa Google Home, 2 Gang, White which gave me even more issues and did not work n HA at all really!
