Has anyone started having issues with sensors dropping out and coming back online randomly since Home Assistant 2023.2.3 update?
Not that I’m seeing in practice or in logs.
Yes. I had to do the following (one by one for all 43 of my esphome devices):
- Delete the device from home assistant on the Settings → Devices & Services page (don’t worry it will all come back).
- Delete the password from my esphome device yaml (I had password and encryption).
- Upload the new config to the device.
- Add the discovered device back to home assistant.
If I did not do this I had continual drop-outs after removing the password. Others reported the same in the release notes topic for devices they had deleted the password from.
in my config, none of my 3 devices is shown in the dashboard anymore. They are still in the Integration panel for ESPHome, but the add-on dashboard is empty
fwiw, I have not changed anything to those devices , and dont use pi’s either, other than wifi…
Are the device yaml files still in config/esphome
yes they are:
last changed on dec 2 and dec 14 respectively, though I seem to recall having updated the devices in the dashboard later than that
Things to try (in order):
- Clear your browser cache, try a different web browser.
- Restart the addon.
- Reinstall the addon.
All of my 20+ ESPHome devices showed as working on the ESPHome page but HAS show all as unavailable.
I tried restoring the backup made with the 2023.4.0 (which seems to have failed) but everything came up after a reboot.
