i got a esxi host that i have installed HAos. I have passedthrough the usb from the host to HA but all i get is:
usb 1-1: device not accepting address 3, error -110
usb usb1-port1: unable to enumerate USB device
ive got pretty default config on my HA. I have tried adding the usb port to a windows server and it works just fine. Really need some help understanding this.
How did you configure the USB device on the vm? I used to get a lot of errors in the console before I switched the 2.0 virtual controller a USB 3.0 controller on the vm it self.
What version of ESXI are you running?
I started running into issues somewhere around 6.8 with passing through usb audio and finally gave up and switched to Proxmox.
What happens if you delete the PCI device 0, click OK to close the settings, re-open settings and try to add just an USB device (not a controller)? What hardware are you running on and how is the USB stick connected?
usb stick is connected to the host (dell powerdge 720) and if i remove it, i would remove the passthrough to the home assistant. And adding a usb device from host is not possible apperently.
I run on a Poweredge too and have never had the need of adding PCI devices to get USB passthrough. Could you try what I suggested? Your device should be available through this menu:
