I’m having an issue with drop down and date/time selection when editing a Lovelace card or trying to select a date from a date selector window on a Lovelace Panel. I’m not able to determine the cause or actions that cause the issue to appear. I have however found that if I refresh the browsers window (F5), that I’m able to select a date. Unfortunately I’m not able to select an entity from the dropdown list.
HACS is installed. No themes are installed but I have installed the Weather Card. This integration was installed long before the above noted issue appeared.
I have tried Chrome, MS Edge and HA browsers. All exhibit the same behaviour. I’ve also restarted HA and rebooted the server. No difference.
Has anyone else experienced this issue? Anyone have an idea where I might start looking for the problem.
System Health
version
core-2022.5.5
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.9.9
os_name
Linux
os_version
5.15.41
arch
aarch64
timezone
America/Toronto
Home Assistant Community Store
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
GitHub API Calls Remaining
4947
Installed Version
1.25.5
Stage
running
Available Repositories
1045
Downloaded Repositories
8
Home Assistant Cloud
logged_in
true
subscription_expiration
June 22, 2022, 8:00 PM
relayer_connected
true
remote_enabled
true
remote_connected
true
alexa_enabled
false
google_enabled
true
remote_server
us-east-1-1.ui.nabu.casa
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
Home Assistant Supervisor
host_os
Home Assistant OS 8.1
update_channel
stable
supervisor_version
supervisor-2022.05.3
docker_version
20.10.14
disk_total
113.9 GB
disk_used
9.0 GB
healthy
true
supported
true
board
odroid-n2
supervisor_api
ok
version_api
ok
installed_addons
SSH & Web Terminal (10.1.3), Node-RED (11.1.2), Home Assistant Google Drive Backup (0.107.3), Samba share (9.6.1), Check Home Assistant configuration (3.10.0), Network UPS Tools (0.10.0), Studio Code Server (5.0.5), Z-Wave JS (0.1.60), SQLite Web (3.4.0), ESPHome (2022.5.1)
Hello
My first post.
I have the same problem.
Version 2022.10.0
Br Jonas
Some comment about HA and the unpaid support team.
I have started to use this program and I am really impressed. Thanks all of you that support us beginners when we take our first unsteady steps in the home automation world.
Thanks again.
