Yes, there should be the same error but packet info should be logged.
Did you clear the __pycache__
directory?
directory?
Iāve just pushed new version. Please try.
after some time I now have the time to play with this agin just updated to the lastest release, and tried to add the intergration again, but I still having trouble, I put in /dev/hidraw2 and pin, and the dosenāt do anything, and I got the following in the log
Iām not sure but itās possible that it does not work when both integrations share the same port.
Is the integration working or not? This packet is enabled always in debug.
Could you please post the packet as text?
if i go to integration and add Jablotron100 it starts and ask for port and pincode, i then enter the port used with the old one /dev/hidraw2 then nothing happens, not sure what you mean by post packets as text
You posted the packet from logs as image. I can check it but itās difficult nowā¦
2020-09-24 19:15:53 DEBUG (ThreadPoolExecutor-6_0) [custom_components.jablotron100] 4008024a412d3130364b0010f50000000000000098290010000000000c0000000100000095d40000000000006c0400100b00000004460010000000006d540300
Do you have JA-106K ? I will prepare new version to support it. The integration currently allow only JA-101
yes it is a JA-106K so thats why
Try latest version https://github.com/kukulich/home-assistant-jablotron100/
Weāll see if it works.
thank you thank you thnak youā¦ this is so cool so easy to have all zones, really great work:-)
one question why canāt I see any text in some of the boxes
Thereās currently only english and czech translation. What language do you use?
danish language I will just change to English the device match the device number in flink??
If you translate this file to danish, you will have danish version: home-assistant-jablotron100/jablotron100/strings.json at 0225910c1cd363b8cabfac98b5f0582dbe1e38ab Ā· kukulich/home-assistant-jablotron100 Ā· GitHub
If you send it to me, Iāll add it to next version
Yes.
ok so if I have 25 devices I need to them in the ordre as in flink? the picture is some of the devices I have, what do I do with device 9 and 10 there are no devices on that place
Yes, you have to match the same order. For 9 and 10 just choose āotherā - āotherā is ignored currently.
super :-)ā¦ I have translated to danish, what do I do with the file??
Put it to ātranslationsā folder: https://github.com/kukulich/home-assistant-jablotron100/tree/master/jablotron100/translations
I think the right name for danish should be da.json
