J'ai installé HAos sur un raspberry 3 B mais il ne semble pas vouloir démarrer!
Hi Victor. This is an English only forum. Please update your post to English or your post will be locked. Or you can get help in another language by following this post:
Getting help in languages other than English.
**Victor Scaglia’s post in English:**
After flashing the SD card with “haos_rpi3-64-14.1.img.xz” then inserting it into the Raspberry 3 B, it seems to boot and install the system but I find myself with a screen that tells me:
Waiting for the Home Assistant CLI to be ready…
[WARN] Home Assistant CLI not starting! Jump into emergency console…
Unfortunately, I don’t speak English and I don’t understand what’s going on. then, it is not indicated anywhere what is the procedure to follow when we reach this level and what should happen when the raspberry starts with HAOS in the SD card?
and of course, I cannot access this small server from my phone or from the link: [homeassistant.local:8123] which is indicated on the page: Raspberry Pi - Home Assistant
There you go, I would really like to use my Raspberry to make a Home Assistant server!
Is there a tutorial that precisely describes everything that can happen and how to respond to it using the hardware I’m using?
Thank you in advance for all your answers, I am retired so I have time to devote to it!
