I think I know what the issue is. I’ll have a look when I get home.
I’ve put in a fix for set_light. Update hass-aqualink with “git pull” and restart homeassistant.
Works perfect now. Thanks!
The lights work but I’m getting all kinds of errors in my log. When I disable the aqualink custom compoent the errors go away. Here are a few…
Executing <Task pending coro=<Entity.async_update_ha_state() running at /usr/src/app/homeassistant/helpers/entity.py:220> wait_for=<Future pending cb=[<TaskWakeupMethWrapper object at 0x7f352480a0d8>()] created at /usr/local/lib/python3.7/site-packages/aiohttp/streams.py:586> cb=[_wait.._on_completion() at /usr/local/lib/python3.7/asyncio/tasks.py:440] created at /usr/local/lib/python3.7/asyncio/tasks.py:361> took 0.210 seconds
Executing <TimerHandle _async_create_timer..fire_time_event created at /usr/src/app/homeassistant/core.py:1265> took 0.115 seconds
Executing <Handle <TaskWakeupMethWrapper object at 0x7f356d8b0438> created at /usr/local/lib/python3.7/asyncio/futures.py:323> took 0.563 seconds
Yeah. they’re not errors. It’s some debugging that I forgot to remove.
I have had the hardest time setting this up and I know it should be simple. I have followed the instructions to instal the files via git, and have the required entry in my configuration.yaml.
What am I doing wrong?
The error that I receive is:
2019-05-05 06:49:24 ERROR (MainThread) [homeassistant.components.hassio] Integration not found: aqualink
Here are the files:
➜ config ls custom_components/aqualink -l
total 44
-rw-r--r-- 1 root root 1515 May 5 06:44 LICENSE
-rw-r--r-- 1 root root 2203 May 5 06:44 README.md
-rw-r--r-- 1 root root 5439 May 5 06:44 __init__.py
-rw-r--r-- 1 root root 4149 May 5 06:44 climate.py
-rw-r--r-- 1 root root 3138 May 5 06:44 light.py
-rw-r--r-- 1 root root 47 May 5 06:44 pytest.ini
-rw-r--r-- 1 root root 49 May 5 06:44 requirements.txt
-rw-r--r-- 1 root root 1851 May 5 06:44 sensor.py
-rw-r--r-- 1 root root 1905 May 5 06:44 switch.py
Here is my configuration.yaml entry:
aqualink:
username: !secret aqualink_username
password: !secret aqualink_password
Can you do ls -la /config/custom_components, just to check permissions/ownership on the directory.
Things look good otherwise. What version of HA are you running? I’m running 0.92.2 and while I suspected the lack of manifest.json file to be a potential issue, it’s not mandatory for custom components.
I am running Home Assistant 0.92.2 and here is my ls -la /config/custom_components. Thank you.
➜ config ls -la /config/custom_components
total 16
drwxr-xr-x 4 root root 4096 May 5 06:44 .
drwxr-xr-x 7 root root 4096 May 5 10:00 ..
drwxr-xr-x 2 root root 4096 Mar 30 11:10 __pycache__
drwxr-xr-x 3 root root 4096 May 5 06:49 aqualink
Hi Flauran,
Any chance you can remove the debugging? Thanks again for you work!
Switched over to your new version, working great including the light…
On a side note, has anyone seen salt levels etc show up, even in the app… wondering if I need some additional hardware.
I’m currently running Hassio. I have manually copied over the (raw) files to an aqualink folder in custom_components folder. I am unsure on how and where to place the api file(s) from PyPi.org. Any help would be appreciated.
I don’t get ph / orp / salt levels either. Guessing this is hardware-dependent.
I’ll do that tonight.
Yeah, I guess I have more to learn: cannot seem to figure out how to “run bash commands from Homeassistant directory” for a Hassio system. Thank you for your response.
You might need to install the “SSH & Web Terminal” add-on from the Add-on store first to be able to run git commands.
That helped. I learned something new in regards to the “SSH & Web Terminal” add-on. Your component works great. Thank you.
Flauran - wanted to let you know that I was able to get everything working. I am not sure what was wrong, but did a fresh install of Hassio and reinstalled. Everything is working perfectly. Thank you for your help.
Glad you got it working, I ran out of ideas!
Never answered your question. Yes, the component support Aux devices. There’s also some hardcoded cover-related values in the output of the API which makes me think some RS systems have dedicated cover ports. Either way, would be interested to hear about things are working out for you once the set up is complete!
