Also, if I try and trigger the new device automation from the front-end I get this error
2018-01-17 21:42:33 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/template.py", line 118, in async_render
return self._compiled.render(kwargs).strip()
File "/srv/homeassistant/lib/python3.5/site-packages/jinja2/environment.py", line 1008, in render
return self.environment.handle_exception(exc_info, True)
File "/srv/homeassistant/lib/python3.5/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/srv/homeassistant/lib/python3.5/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
File "/srv/homeassistant/lib/python3.5/site-packages/jinja2/sandbox.py", line 385, in getattr
value = getattr(obj, attribute)
jinja2.exceptions.UndefinedError: 'trigger' is undefined
File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
result = coro.send(None)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/automation/__init__.py", line 336, in async_trigger
yield from self._async_action(self.entity_id, variables)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/automation/__init__.py", line 426, in action
yield from script_obj.async_run(variables)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/script.py", line 151, in async_run
yield from self._async_call_service(action, variables)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/script.py", line 181, in _async_call_service
self.hass, action, True, variables, validate_config=False)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/service.py", line 80, in async_call_from_config
config[CONF_SERVICE_DATA_TEMPLATE]))
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/service.py", line 76, in _data_template_creator
for key, item in value.items()}
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/service.py", line 76, in <dictcomp>
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/service.py", line 78, in _data_template_creator
return value.async_render(variables)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/template.py", line 120, in async_render
raise TemplateError(err)
homeassistant.exceptions.TemplateError: UndefinedError: 'trigger' is undefined
thanks!
