Keenetic NDMS2 Router Addon Password Change
Hello, i have a Keenetic Hopper DSL KN3610. I installed the plugin on HA and it works fine. However, after changing the router interface password, I couldn’t find a way to change it in HA. I can’t do it without deleting and reinstalling the plugin. If I delete the plugin, all entities and automations are also deleted.
In short, is there any chance to add the password to the config without removing this plugin?
Thanks.
If you by plug-in mean integration, that is not correct. The automations do not get deleted even if entities are missing. If you use states in your automations these will function as expected after you delete and install the integration again (assuming you keep the entity names the same) If you use devices_ids you might need to modify the automations. Why and how to avoid device_ids in automations and scripts
Thanks for the info. Yes, I was talking about integration. I use states in my automations. When I deleted and reinstalled Zigbee2mqtt, my automations were deleted, that’s why I asked. I’ll try deleting and re-adding as you said, let’s see if it will be deleted.
