Hi, I am planning to use the slider component to move a 12v chain drive window opener to open a window to various stop points. This will be done by calculating the amount of time that the motor is allowed to stay on, with perhaps 4 pre-set positions starting at zero (window closed), then stops implemented at 25, 50, and 100% (fully open). It seems to me I will need to know what the previous setting was, in order to make it move in the correct direction. Is there a way to store the state of the slider? Once it has been moved to trigger an automation, I’m pretty sure I need to know which way it was moved.
Hi @logman, just an idea, don’t know if this works.
Maybe multiple automations with triggers from the slider:
to: 25
to: 50
to: 25
Hello @VDRainer, thanks for that, I did not realize there was any syntax like that as the input_slider page does not seem to show it.
So the automation would look something like this?
input_slider:
window_opener1:
icon: mdi:window-closed
min: 0
max: 100
step: 25
initial: 0
automation:
- alias: 'Test Window Opener1'
platform: state
entity_id: input_slider. window_opener1
state: 'on'
service: mqtt.publish
data_template:
topic: "setWindow1"
retain: true
to: 25
payload: '{{ states.input_slider.window_opener1.state | int }}'
run_script.A
to: 0
run_script.B
As i said, don`t know, give it a try.
Edit:
I mean:
automation:
platform: state
entity_id: input_slider.window_opener1
to: '25'
Hello @VDRainer, it’s a no go, unfortunately, but I’m wondering if you have seen the ‘from’ and ‘to’ syntax used elsewhere? I can’t seem to find any reference …
Hi, I finally found the correct syntax, here’s the example:
'Volume has gone from {{ trigger.from_state.state }} to {{ trigger.to_state.state }} ’
I found it here:
I put a fully operational script in this entry for window blinds, which uses essentially the same script as window openers:
Thanks for the tip, it helped me to make all this work!
Cheers
