I have a Kerui motion sensor which is 433 MHz. I publish to home/rtl_433 and the following is displayed after the sensor trips. (several other items publish to this topic)
Made some progress. Got the binary_sensor to flip to on but now I don’t know how to shut it down. The MQTT dump I posted above is all. Sensor only reports on, not reset or off.
- platform: mqtt
state_topic: home/rtl_433
value_template: >
{% if value_json is defined and value_json.id == 924442 %}
{{ value_json.state }}
{% endif %}
payload_on: 'motion'
payload_off: 'standby'
It’s most likely the sensor only sends one signal, so, you need to create a fake off signal using an automation. See my example below. I use this for a number of 433 mhz motion sensors to reset them to off after 1 second, as they detect motion every 6 seconds.
binary_sensor.yaml
- platform: mqtt
qos: 1
state_topic: "home/433toMQTT"
payload_on: "2890473"
payload_off: "2890473off" #This is a fake 'off' payload that gets sent with an automation
optimistic: true
retain: false
automation.yaml
# MOTION SENSOR 1 - OFF TIMER #
- alias: Motion Sensor 1 - Off Timer
hide_entity: true
platform: state
entity_id: binary_sensor.motion_1
to: 'on'
for:
seconds: 1
service: mqtt.publish
topic: 'home/433toMQTT'
payload: '2890473off'
retain: 'true'
Thanks. I have a weird condition where everything rf gets published to home/rtl_433
I can’t quite nail the automation because I’m pretty sure I have to value_template or filter template and I’m not so good at that. This is a binary sensor that shows up and does trip when triggered. Just can’t get the sensor to “reset”
- platform: mqtt
qos: 1
value_template: >
{% endif %}
payload_off: 'motionoff'
optimistic: true
retain: false
Automation
automation 21:
alias: Motion Sensor Off
hide_entity: false
platform: state
entity_id: binary_sensor.pantry_motion
to: 'on'
for:
seconds: 1
topic: 'home/rtl_433'
payload: 'motionoff'
retain: 'true'
The MQTT server does see the published “motionoff” but I’m certain that my value template can’t find it and I’m stumped.
variable for the MQTT Binary Sensor. I have it set up but I’m at work VPN’d into my network and I can’t test it until my daughter wakes up and moves around the house which of course could be HOURS. But I’m hopeful it might work.
