I actually tried following that before, but I don’t see a “logger.set_level” at all in my list. The closest I have is “logbook.log”. Is that the same thing?
No, it should be in your list.
Maybe your advanced mode is off in your profile:
That was my first thought too, but it’s on.
just a wild guess but maybe you removed logger
try dropping this in your configuration.yaml:
logger:
default: warning
Yeah, I don’t think I removed it - I don’t recall it ever being there. I went ahead and added it back into my configuration.yaml and I see it in my list now.
What version of lock-manager have you installed?
It says v0.0.34 in the info screen.
And what does your latest lovelace UI look like?
No, that’s what I want to see. And that’s incorrect. Delete it and paste the generated lovelace again
Hmm, I did actually do that after I updated the component - is there anything I should do to get it to regenerate that file?
Edit: weird - now it shows differently
PIN status shows as “Connecting” for the 2 codes
When you update, you have to regenerate the lovelace code. Open the lock-manager integration and press submit. Then use that file to make the new view
Edit: ok, it looks like you did update the lovelace after all. Just not what you posted before.
Ahh, that’s what I didn’t do the first time. I do see the updated interface now, but my two codes appear to be “Connecting” PIN status.
Expand the debug section on the PINS in question and post a pic
I assume you restarted HA already. But your PIN sensor isn’t working. Do you have a timer named something like frontdoor refresh lock node? Is it active?
Yes. Click start, then click finish
