Did you change your lock to use 6 digit PINs?
I went thru your msg history and it appears you are using the BE469. Can you confirm the exact model number? How old is the lock?
@FutureTense I have started my dive into Home Assistant over the last two weeks (moving over from SmartThings Webcore). I have a Kwikset 916 Smart Lock, I āthinkā I have followed your instructions on how to install the lock manger but I am getting a lot of āEntity not available: input_text.frontdoor_xxx_#ā issues on the lovelace dashboard. Was something supposed to create them? I assume I missed or screwed up a step.
I installed the module through HACS, I renamed the lock entities to have ā_frontdoorā at the end.
- lock.kwikset_spectrum_brands_smartcode_916_locked_frontdoor
- zwave.kwikset_spectrum_brands_smartcode_916_frontdoor
- sensor.kwikset_spectrum_brands_smartcode_916_access_control_frontdoor
- sensor.kwikset_spectrum_brands_smartcode_916_alarm_level_frontdoor
- sensor.kwikset_spectrum_brands_smartcode_916_alarm_type_frontdoor
- sensor.kwikset_spectrum_brands_smartcode_916_battery_level_frontdoor
- sensor.kwikset_spectrum_brands_smartcode_916_burglar_frontdoor
- sensor.kwikset_spectrum_brands_smartcode_916_power_management_frontdoor
- sensor.kwikset_spectrum_brands_smartcode_916_sourcenodeid_frontdoor
The intregration seemed to complete correctly (the frontdoor folder was created).
I was confused on user code sensor but it only had one available option which was
For the Access Control Sensor I used
I am not using OZW that I am aware of (I donāt have MQTT installed)
Card-tools, fold-entity-row and auto-entities are installed. I manually tested fold-entity with some light switch to determined that installing them via HACS worked.
I added in the script, automation, binary_sensors and input_booleans from the GIT directions, but have since removed them back out during my trouble shooting.
Any through what I did wrong?
Yes, I have a 6-digit PIN manually entered into the lock so we can still use it while Iām trying to get this configured in HA.
However, I do see that the value for PIN length in the Z-wave integration shows as 4, instead of 6, but every time I try to update it, it ignores my input and doesnāt change anything.
Yep, thatās correct. The exact model number is: BE469WK V CAM 619. I bought it in July from Amazon.
I wouldnāt use 6 digit PINs for now. Especially until you get things working. And if youāre using the older Schlage, itās going to be harder to debug things if you use zwave. Do you have access to the add on store? Installing OpenZWave will make your life easier.
OK, I just set it to 4 digits, but it still shows as āConnectingā as the PIN status.
Iāve never used OZW - do I have to completely re-pair everything to use it?
@FutureTense You are active on here! Thank you so much for the time you spend helping other out.
Yes - I had restarted HA, and I did it just again right now for good measure. No change. What āprocessā creates those inputs? is it one of the automations?
I did notice that your open_zwave_network_XXX Automations refer to OZW, which I am not using. But I assume that is not the issues?
You shouldnāt. But even if you did, ozw is the future. Zwave is not being supported
Hi FutureTense,
I am having the same issue as coolsaber57. I am running HassOS 4.15 with Supervisor Version 2020.10.0. In addition I am running lock-manager v0.0.34
Below is a screenshot of my UI
I have enabled debugging for this intergration and this is what I see when I go to send a code using the UI.
Logger: homeassistant.components.script.frontdoor_conditional_notify
Source: helpers/script.py:1122
Integration: Script (documentation, issues)
First occurred: 11:29:14 AM (1 occurrences)
Last logged: 11:29:14 AM
frontdoor_conditional_notify: Error executing script. Service not found for call_service at pos 2: Unable to find service script/frontdoor_manual_notify
Logger: homeassistant.components.automation.frontdoor_lock_notifications
Integration: Automation (documentation, issues)
frontdoor Lock Notifications: Error executing script. Service not found for call_service at pos 1: Unable to find service script/frontdoor_manual_notify
Source: core.py:1398
While executing automation automation.frontdoor_lock_notifications
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 426, in async_trigger
await self.action_script.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1010, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 245, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 253, in _async_step
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 463, in _async_call_service_step
await self._async_run_long_action(service_task)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 422, in _async_run_long_action
long_task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1448, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1483, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 215, in service_handler
await script_entity.async_turn_on(
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 320, in async_turn_on
await coro
await getattr(
long_task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1398, in async_call
raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: Unable to find service script/frontdoor_manual_notify```
Iām more active on discord. Hint hint.
Those inputs are created in the packages directory. Did you ever add packages: !include_dir_named packages
to your configuration.yaml?
Well, for starters you donāt have the latest UI. Did you re-run the integration options and press submit?
Hmm, everything Iāve read about OZW is that itās not ready for primetime yet.
I doubt youāre using zwave features (not the native protocol) that much to make a difference. But for lock-manager ozw is preferred, mostly because the two developers use that, and it makes it easier to support you guys.
Iām out for a while. Peace out.
Got it, thank you - Iāll take a look
Any luck getting OZW setup? Its kind of confusing to meā¦
@FutureTense Alright adding in packages: !include_dir_named packages seemed to make a HUGE difference. Thanks for that hint. The system is still not working
But that being said, I need to add in some of your scripts, automations and input_booleans, and sensors that you mention in your GIT hub back in (I still have to do some debugging on my end).
Things I am noticing: Attempting to load a pin just has the Pin Status stuck in āConnectingā. I AM connected to the lock (I can use the lock/unlock button at the top to trigger that and it works).
I still have NO idea what fold-entity-row does not work, I tested it on some light switches and it seemed to work fine.
I saw you mentioning to coolsaber57 that OZW is the way of the future. I have the HACS installed, but I canāt find anything in there to install - Could that be part of the issues I am seeing? it is worth installing? If so I am sure I can find a guide online to do it, unless it is simple and you can point me in the right direction.
I havenāt tried yet, Iām a little afraid of screwing up all my automations that involve z-wave devices, so Iām trying to read more about the process of switching over. Let me know if you find a good guide on doing it.
Edit: it looks like you can test it before you fully commit:
Then to fully switch over:
lol yea good call. Iāve been trying by fumbling thru whatever docs I could find and now all my Z-Wave devices are āunavailableā.
Maybe Iām following the wrong instructions, but Iām hating that I have to install and configure 2 addons and 2 integrations (OZW addon, OZW integration, MQTT broker addon, MQTT integration) that somehow talk to each other? Am I crazy?
