If you want to disable notifications for users you have to disable them here:
I just picked up a 2nd Schlage connect Z-Wave Plus lock for my side entrance, I already have a network key in my configuration.yaml from my front door lock, Do I need to generate another key for my new lock and add it below the existing network key before adding it to my Z-Wave network?
Just the one. Your secure nodes will use the same network key. (assume youâre talking about the z-wave configured network key)
Yes that is correct,
The Z-Wave network key I already have from when I added my first lock. Just going to install the lock now
I must be stupid⌠I just migrated from OZW to ZwaveJS. I uninstalled and reinstalled keymaster, deleted and updated the lovelace view with the one from the reinstalled integration, and I get no response when I toggle the enabled toggle. All of my key slots show disabled, and donât update to connecting or connected when I hit the toggle.
A few notes:
- Most obviously, allow_automations is set to on.
- I made sure I followed the directions, including the pre-install directions (made that mistake my first time)
- When I migrated, my Schlage BE469 came across as Unknown Manufacturer/Unknown product, but HA recognized it as a lock and itâs operational.
- I have the following entities under the lock:
sensor.front_door_alarmlevel
lock.front_door_currentmode
sensor.front_door_battery_level
binary_sensor.front_door_the_current_status_of_the_door
binary_sensor.front_door_low_battery_level
sensor.front_door_alarmtype
Anyone got help/advice for where to start troubleshooting? I donât see anything of interest in configuration/logs
Version of zwavejs addon/container youâre using?
Please post a screenshot of your keymaster config screen.
using ZwaveJS2MQTT with the ZwaveJS integration - MQTT server is shut down.
KeyMaster
Select the lock to setup and code slots to create.
Paths are relative to your Home Assistant config folder (e.g. /config/packages/keymaster should be entered as packages/keymaster)
If you are using Z-Wave JS you may or may not have alarm level and alarm type entities. If you do, select them on this form, otherwise you can use the sensor.fake values as placeholders.
Select your lock
Code Slots
10
Start from code slot #
1
Lock Name (ie: frontdoor)
frontdoor
Door Sensor
binary_sensor.fake
Alarm Level/User Code Sensor (from lock)
sensor.fake
Alarm Type/Access Control Sensor (from lock)
sensor.fake
Path to packages directory
packages/keymaster/
Hide PINs in UI?
Path to child locks file
Iâve also tried using sensor.front_door_alarmlevel and sensor.front_door_alarmtype in the appropriate field with the same results.
I want to set the PINs/schedules/etc. in one place and have them copied to each of my three identical door locks (kwikset 910s). Is there an easier way to do this without writing a bunch of automation to copy one of the input values to the other input values (which will take longer than simply duplicating the info on each page)?
Tx!
Yes, use the child locks feature.
Iâve tried a bunch of things but I canât figure out how child locks config is supposed to work - Iâm starting with just 2 locks.
- Do I create an integration for each lock?
- Do I point each integration at the child locks file?
- Do I specify each lock in the child locks file?
Iâm getting a check config error that the lock name specified in the child locks file doesnât exist (Package child_locks setup failed. Component front_door Integration âfront_doorâ not found), even though I added the front_door integration.
Whatâs even more peculiar is that when I did this the other lock folder in packages/keymaster disappeared (so I only have the front_door folder now)
Tx!
No just your âParentâ lock that youâll be inputting the codes for via lovelace.
Nope
Only the locks that are to copy your âParentâ lock go into the child locks folder.
Post the lock entities (the lock.whatever of the 2 child locks you are syncing), Iâll help you make the file.
Thanks so much for your help. The entities are:
lock.lock_deck_north_door
lock.lock_garage_side_door
Here you go.
deck_north_door:
lock_entity_id: lock.lock_deck_north_door
alarm_level_or_user_code_entity_id: sensor.fake
alarm_type_or_access_control_entity_id: sensor.fake
garage_side_door:
lock_entity_id: lock.lock_garage_side_door
Thanks. Iâve added this to a /config/child_locks.yaml
When I specify that file (literally specify child_locks.yaml) in the integration, I immediately get a success message, but the front_door folder (the name of the door) isnât created.
When I edit the options, the child_lock.yaml path is not there.
Sounds like an error is being hit, try enabling debugging and creating a github issue please.
I can create a bug, but if you have any ideas how I might work around it, hereâs the trace⌠Tx.
File â/config/custom_components/keymaster/init.pyâ, line 418, in update_listener
primary_lock, child_locks = await generate_keymaster_locks(hass, config_entry)
File â/config/custom_components/keymaster/helpers.pyâ, line 129, in generate_keymaster_locks
child_locks = [
File â/config/custom_components/keymaster/helpers.pyâ, line 130, in
KeymasterLock(
TypeError: init() missing 1 required positional argument: âdoor_sensor_entity_idâ
2021-03-26 17:56:11 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Front Door for keymaster
File â/usr/src/homeassistant/homeassistant/config_entries.pyâ, line 248, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File â/config/custom_components/keymaster/init.pyâ, line 166, in async_setup_entry
child_locks = [
KeymasterLock(
2021-03-26 17:59:40 ERROR (SyncWorker_8) [custom_components.keymaster.config_flow] The child locks file (/config/child_locks) does not exist
2021-03-26 17:59:49 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
Ya this is going to require code fixes, please create an issue.
@firstof9 any thoughts on my situation?
Enable debugging and check the Home Assistant log.
Iâm seeing several repeated loops of this in the logs:
2021-03-26 22:42:38 DEBUG (SyncWorker_7) [custom_components.keymaster] DEBUG: Ignoring code slot with * in value for code slot 1.
2021-03-26 22:42:38 DEBUG (SyncWorker_7) [custom_components.keymaster] Work around code in use.
2021-03-26 22:42:38 DEBUG (SyncWorker_7) [custom_components.keymaster] Utilizing FE599 work around code.
2021-03-26 22:42:38 DEBUG (SyncWorker_7) [custom_components.keymaster] DEBUG: Ignoring code slot with * in value for code slot 2.
2021-03-26 22:42:38 DEBUG (SyncWorker_7) [custom_components.keymaster] DEBUG: Ignoring code slot with * in value for code slot 3.
2021-03-26 22:42:38 DEBUG (SyncWorker_7) [custom_components.keymaster] DEBUG: Ignoring code slot with * in value for code slot 4.
2021-03-26 22:42:38 DEBUG (SyncWorker_7) [custom_components.keymaster] DEBUG: Ignoring code slot with * in value for code slot 5.
2021-03-26 22:42:38 DEBUG (SyncWorker_7) [custom_components.keymaster] DEBUG: Code slot 6 not enabled
2021-03-26 22:42:38 DEBUG (SyncWorker_7) [custom_components.keymaster] DEBUG: Code slot 7 not enabled
2021-03-26 22:42:38 DEBUG (SyncWorker_7) [custom_components.keymaster] DEBUG: Code slot 8 not enabled
2021-03-26 22:42:38 DEBUG (SyncWorker_7) [custom_components.keymaster] DEBUG: Code slot 9 not enabled
2021-03-26 22:42:38 DEBUG (SyncWorker_7) [custom_components.keymaster] DEBUG: Code slot 10 not enabled
