Yes, it was strange that kia uvo servers returns values in different units. Can one of you create an issue in github? My proposal is to render all units using home assistant metric configuration, makes sense you guys?
What about a config parameter on integration install ? Is that possible ? In the UK we still use miles…
I believe your home assistant setup is configured to use imperial which should default to miles, right? You can check them through configuration - general section
Na, I’m set to metric. All other things are metric apart from miles.in the UK
please track over here: Support configurable distance unit (km vs miles) · Issue #33 · fuatakgun/kia_uvo · GitHub
Apologies for a most likely very simple question, but I am a bit new to both yaml, and homeassistant.
Do anyone here have an example of some lovelace code that would give me a “force_update” button on a dashboard?
I am looking for something like this below, but where the “9 minues ago” is clickable, and would perform the force_update service call when pressed
Enjoy;
type: grid
cards:
- type: button
tap_action:
action: call-service
service: kia_uvo.update
service_data: {}
target: {}
hold_action:
action: none
show_icon: true
icon: 'mdi:access-point'
- type: button
tap_action:
service: kia_uvo.force_update
service_data: {}
target: {}
hold_action:
action: none
show_name: true
show_state: false
icon: 'mdi:access-point-check'
columns: 2
Hi, I installed this add-on in HACS and see it installed there. Where can I setup my username and password? Don’t see an example yaml or anything
install over HACS or manually by copying custom_components
folder, restart you HA instance, go to integrations page, click Add button and search for Kia Uvo
, select it and configure it on UI.
Hi, crazy. I did not see the integration. But later it was there. Maybe a typo. Thanks for all your work!!!
Just taken delivery of a Kia Soul EV and was delighted to find this integration. Despite being a bit rusty with HA everything has installed and is working well, including changing range to miles.
Many thanks @anon63427907 for putting this together.
Thanks for feedback, there are 2 hidden services start_climate and stop_climate. I am not able to test them locally as i own a PHEV version, but i would be glad if you can test in your car and share results.
I’m happy to test anything out. Just bear with me and dumb questions as I’m not a HA/yaml expert.
Regarding the 2 hidden services I thought they might be ‘behind’ Soul EV Defroster in the same way Lock & Unlock can be initiated with Soul EV Door Lock.
Not so, I get a ‘service not found’ message.
Where do I find the hidden services relating to climate?
Edit: brain engaged. Found in Services! Will have a play and report back.
My first play seems to work.
Buttons on Lovelace set up for Kia Uvo: start climate & Kia Uvo: stop_climate via call-service using the entity ‘binary_sensor.soul_ev_air_conditioner’.
Starting and stopping are confirmed on the Uvo App. So basics seems to work.
Happy to hear that. Let me create specific components to control the car state, as you might know better, this is intended to control AC state of car, rather than starting car. Let me know if you knoe sth different.
Nice work! Seems to work mostly fine with my MY20 e-Niro. However, the stop_climate
service behaves a bit strange. I have defrost and heating enabled under the HVAC setting in the Uvo App. start_climate
starts A/C, defroster, back window heater, and steering wheel heater, as expected. However, after calling stop_climate
the defroster still shows as on, both in the Uvo App and in Home Assistant. Everything else is turned off properly.
I am following this specific issue over here, please comment when you have time: Test start/stop car commands on EV cars · Issue #39 · fuatakgun/kia_uvo · GitHub
Enable debugging as per the doc:
You can enable logging for this integration specifically and share your logs, so I can have a deep dive investigation. To enable logging, update your configuration.yaml
like this, we can get more information in Configuration → Logs page
logger:
default: warning
logs:
custom_components.kia_uvo: debug
Another thought: did you migrate from an UVO account, and if so did u change password when you migrated your account? If so try with your old uvo password. I still have to use my old UVO password and I migrated my account over a month ago.
As pointed out earlier, logout in your app and try to login again, you will get an directive to migrate your account from Kia to UVO. After migration, give it a day to sync all servers, then you should be good to go.
