Need help adding a button for a force_update for Ioniq 5 in Kia Uno - Canada
Continuing the discussion from Kia Uvo Integration:
I found the above but being new to HomeAssistant I’m not sure where the code mentioned in the post should go. Seems not in configuration.yaml as I get these errors when doing a Check Configuration:
Integration error: type - Integration ‘type’ not found.
Integration error: cards - Integration ‘cards’ not found.
Integration error: columns - Integration ‘columns’ not found.
ScreenShot_20221205213556
Thank you. Tough learning curve being new to HAss but certainly worthwhile.
