I’m not completely satisfied yet.
What I’m trying to achieve:
Have the modes ‘low, high and af’ available in home assistant and in google home.
I can set the eco mode in tuya local, but then I can’t control the temperature in google home because it’s in eco mode (and google won’t let you change the temperature?). With the ‘COOL’ mode you can change the temperature in google home. I’ve set the antifrost to ‘AUTO’ now. But you can leave that out if you want.
So in short: I’ve added ‘HVAC_MODE_COOL’ for the eco mode and added a mode set ‘High/low/af’.
In tuya local just select these values:
Don’t set current action set or eco dp, eco value or presets dp.
My climate.py
"""Platform to locally control Tuya-based climate devices."""
import asyncio
import logging
from functools import partial
import voluptuous as vol
from homeassistant.components.climate import (
DEFAULT_MAX_TEMP,
DEFAULT_MIN_TEMP,
DOMAIN,
ClimateEntity,
from homeassistant.components.climate.const import (
CURRENT_HVAC_HEAT,
CURRENT_HVAC_IDLE,
HVAC_MODE_AUTO,
HVAC_MODE_HEAT,
HVAC_MODE_COOL,
HVAC_MODE_OFF,
PRESET_AWAY,
PRESET_ECO,
PRESET_HOME,
PRESET_NONE,
SUPPORT_PRESET_MODE,
SUPPORT_TARGET_TEMPERATURE,
SUPPORT_TARGET_TEMPERATURE_RANGE,
from homeassistant.const import (
ATTR_TEMPERATURE,
CONF_TEMPERATURE_UNIT,
PRECISION_HALVES,
PRECISION_TENTHS,
PRECISION_WHOLE,
TEMP_CELSIUS,
TEMP_FAHRENHEIT,
from .common import LocalTuyaEntity, async_setup_entry
from .const import (
CONF_CURRENT_TEMPERATURE_DP,
CONF_ECO_DP,
CONF_ECO_VALUE,
CONF_HEURISTIC_ACTION,
CONF_HVAC_ACTION_DP,
CONF_HVAC_ACTION_SET,
CONF_HVAC_MODE_DP,
CONF_HVAC_MODE_SET,
CONF_MAX_TEMP_DP,
CONF_MIN_TEMP_DP,
CONF_PRECISION,
CONF_PRESET_DP,
CONF_PRESET_SET,
CONF_TARGET_PRECISION,
CONF_TARGET_TEMPERATURE_DP,
CONF_TEMPERATURE_STEP,
_LOGGER = logging.getLogger(__name__)
HVAC_MODE_SETS = {
"manual/auto": {
HVAC_MODE_HEAT: "manual",
HVAC_MODE_AUTO: "auto",
"Manual/Auto": {
HVAC_MODE_HEAT: "Manual",
HVAC_MODE_AUTO: "Auto",
"Manual/Program": {
HVAC_MODE_AUTO: "Program",
"m/p": {
HVAC_MODE_HEAT: "m",
HVAC_MODE_AUTO: "p",
"True/False": {
HVAC_MODE_HEAT: True,
"1/0": {
HVAC_MODE_HEAT: "1",
HVAC_MODE_AUTO: "0",
"High/low/af": {
HVAC_MODE_HEAT: "high",
HVAC_MODE_COOL: "low",
HVAC_MODE_AUTO: "af",
HVAC_ACTION_SETS = {
"True/False": {
CURRENT_HVAC_HEAT: True,
CURRENT_HVAC_IDLE: False,
"open/close": {
CURRENT_HVAC_HEAT: "open",
CURRENT_HVAC_IDLE: "close",
"heating/no_heating": {
CURRENT_HVAC_HEAT: "heating",
CURRENT_HVAC_IDLE: "no_heating",
"Heat/Warming": {
CURRENT_HVAC_HEAT: "Heat",
CURRENT_HVAC_IDLE: "Warming",
PRESET_SETS = {
"Manual/Holiday/Program": {
PRESET_AWAY: "Holiday",
PRESET_HOME: "Program",
PRESET_NONE: "Manual",
TEMPERATURE_CELSIUS = "celsius"
TEMPERATURE_FAHRENHEIT = "fahrenheit"
DEFAULT_TEMPERATURE_UNIT = TEMPERATURE_CELSIUS
DEFAULT_PRECISION = PRECISION_TENTHS
DEFAULT_TEMPERATURE_STEP = PRECISION_HALVES
# Empirically tested to work for AVATTO thermostat
MODE_WAIT = 0.1
def flow_schema(dps):
"""Return schema used in config flow."""
return {
vol.Optional(CONF_TARGET_TEMPERATURE_DP): vol.In(dps),
vol.Optional(CONF_CURRENT_TEMPERATURE_DP): vol.In(dps),
vol.Optional(CONF_TEMPERATURE_STEP): vol.In(
[PRECISION_WHOLE, PRECISION_HALVES, PRECISION_TENTHS]
vol.Optional(CONF_MAX_TEMP_DP): vol.In(dps),
vol.Optional(CONF_MIN_TEMP_DP): vol.In(dps),
vol.Optional(CONF_PRECISION): vol.In(
vol.Optional(CONF_HVAC_MODE_DP): vol.In(dps),
vol.Optional(CONF_HVAC_MODE_SET): vol.In(list(HVAC_MODE_SETS.keys())),
vol.Optional(CONF_HVAC_ACTION_DP): vol.In(dps),
vol.Optional(CONF_HVAC_ACTION_SET): vol.In(list(HVAC_ACTION_SETS.keys())),
vol.Optional(CONF_ECO_DP): vol.In(dps),
vol.Optional(CONF_ECO_VALUE): str,
vol.Optional(CONF_PRESET_DP): vol.In(dps),
vol.Optional(CONF_PRESET_SET): vol.In(list(PRESET_SETS.keys())),
vol.Optional(CONF_TEMPERATURE_UNIT): vol.In(
[TEMPERATURE_CELSIUS, TEMPERATURE_FAHRENHEIT]
vol.Optional(CONF_TARGET_PRECISION): vol.In(
vol.Optional(CONF_HEURISTIC_ACTION): bool,
class LocaltuyaClimate(LocalTuyaEntity, ClimateEntity):
"""Tuya climate device."""
def __init__(
self,
device,
config_entry,
switchid,
**kwargs,
"""Initialize a new LocaltuyaClimate."""
super().__init__(device, config_entry, switchid, _LOGGER, **kwargs)
self._state = None
self._target_temperature = None
self._current_temperature = None
self._hvac_mode = None
self._preset_mode = None
self._hvac_action = None
self._precision = self._config.get(CONF_PRECISION, DEFAULT_PRECISION)
self._target_precision = self._config.get(
CONF_TARGET_PRECISION, self._precision
self._conf_hvac_mode_dp = self._config.get(CONF_HVAC_MODE_DP)
self._conf_hvac_mode_set = HVAC_MODE_SETS.get(
self._config.get(CONF_HVAC_MODE_SET), {}
self._conf_preset_dp = self._config.get(CONF_PRESET_DP)
self._conf_preset_set = PRESET_SETS.get(self._config.get(CONF_PRESET_SET), {})
self._conf_hvac_action_dp = self._config.get(CONF_HVAC_ACTION_DP)
self._conf_hvac_action_set = HVAC_ACTION_SETS.get(
self._config.get(CONF_HVAC_ACTION_SET), {}
self._conf_eco_dp = self._config.get(CONF_ECO_DP)
self._conf_eco_value = self._config.get(CONF_ECO_VALUE, "ECO")
self._has_presets = self.has_config(CONF_ECO_DP) or self.has_config(
CONF_PRESET_DP
_LOGGER.debug("Initialized climate [%s]", self.name)
@property
def supported_features(self):
"""Flag supported features."""
supported_features = 0
if self.has_config(CONF_TARGET_TEMPERATURE_DP):
supported_features = supported_features | SUPPORT_TARGET_TEMPERATURE
if self.has_config(CONF_MAX_TEMP_DP):
supported_features = supported_features | SUPPORT_TARGET_TEMPERATURE_RANGE
if self.has_config(CONF_PRESET_DP) or self.has_config(CONF_ECO_DP):
supported_features = supported_features | SUPPORT_PRESET_MODE
return supported_features
@property
def precision(self):
"""Return the precision of the system."""
return self._precision
@property
def target_precision(self):
"""Return the precision of the target."""
return self._target_precision
@property
def temperature_unit(self):
"""Return the unit of measurement used by the platform."""
if (
self._config.get(CONF_TEMPERATURE_UNIT, DEFAULT_TEMPERATURE_UNIT)
== TEMPERATURE_FAHRENHEIT
return TEMP_FAHRENHEIT
return TEMP_CELSIUS
@property
def hvac_mode(self):
"""Return current operation ie. heat, cool, idle."""
return self._hvac_mode
@property
def hvac_modes(self):
"""Return the list of available operation modes."""
if not self.has_config(CONF_HVAC_MODE_DP):
return None
return list(self._conf_hvac_mode_set) + [HVAC_MODE_OFF]
@property
def hvac_action(self):
"""Return the current running hvac operation if supported.
Need to be one of CURRENT_HVAC_*.
if self._config.get(CONF_HEURISTIC_ACTION, False):
if self._hvac_mode == HVAC_MODE_HEAT:
if self._current_temperature < (
self._target_temperature - self._precision
self._hvac_action = CURRENT_HVAC_HEAT
if self._current_temperature == (
if self._hvac_action == CURRENT_HVAC_HEAT:
if self._hvac_action == CURRENT_HVAC_IDLE:
self._hvac_action = CURRENT_HVAC_IDLE
if (
self._current_temperature + self._precision
) > self._target_temperature:
return self._hvac_action
@property
def preset_mode(self):
"""Return current preset."""
return self._preset_mode
@property
def preset_modes(self):
"""Return the list of available presets modes."""
if not self._has_presets:
return None
presets = list(self._conf_preset_set)
if self._conf_eco_dp:
presets.append(PRESET_ECO)
return presets
@property
def current_temperature(self):
"""Return the current temperature."""
return self._current_temperature
@property
def target_temperature(self):
"""Return the temperature we try to reach."""
return self._target_temperature
@property
def target_temperature_step(self):
"""Return the supported step of target temperature."""
return self._config.get(CONF_TEMPERATURE_STEP, DEFAULT_TEMPERATURE_STEP)
@property
def fan_mode(self):
"""Return the fan setting."""
return NotImplementedError()
@property
def fan_modes(self):
"""Return the list of available fan modes."""
async def async_set_temperature(self, **kwargs):
"""Set new target temperature."""
if ATTR_TEMPERATURE in kwargs and self.has_config(CONF_TARGET_TEMPERATURE_DP):
temperature = round(kwargs[ATTR_TEMPERATURE] / self._target_precision)
await self._device.set_dp(
temperature, self._config[CONF_TARGET_TEMPERATURE_DP]
def set_fan_mode(self, fan_mode):
"""Set new target fan mode."""
async def async_set_hvac_mode(self, hvac_mode):
"""Set new target operation mode."""
if hvac_mode == HVAC_MODE_OFF:
await self._device.set_dp(False, self._dp_id)
return
if not self._state and self._conf_hvac_mode_dp != self._dp_id:
await self._device.set_dp(True, self._dp_id)
# Some thermostats need a small wait before sending another update
await asyncio.sleep(MODE_WAIT)
self._conf_hvac_mode_set[hvac_mode], self._conf_hvac_mode_dp
async def async_turn_on(self) -> None:
"""Turn the entity on."""
async def async_turn_off(self) -> None:
"""Turn the entity off."""
async def async_set_preset_mode(self, preset_mode):
"""Set new target preset mode."""
if preset_mode == PRESET_ECO:
await self._device.set_dp(self._conf_eco_value, self._conf_eco_dp)
return
self._conf_preset_set[preset_mode], self._conf_preset_dp
@property
def min_temp(self):
"""Return the minimum temperature."""
if self.has_config(CONF_MIN_TEMP_DP):
return self.dps_conf(CONF_MIN_TEMP_DP)
return DEFAULT_MIN_TEMP
@property
def max_temp(self):
"""Return the maximum temperature."""
return self.dps_conf(CONF_MAX_TEMP_DP)
return DEFAULT_MAX_TEMP
def status_updated(self):
"""Device status was updated."""
self._state = self.dps(self._dp_id)
self._target_temperature = (
self.dps_conf(CONF_TARGET_TEMPERATURE_DP) * self._target_precision
if self.has_config(CONF_CURRENT_TEMPERATURE_DP):
self._current_temperature = (
self.dps_conf(CONF_CURRENT_TEMPERATURE_DP) * self._precision
if self._has_presets:
if (
and self.dps_conf(CONF_ECO_DP) == self._conf_eco_value
self._preset_mode = PRESET_ECO
else:
for preset, value in self._conf_preset_set.items(): # todo remove
if self.dps_conf(CONF_PRESET_DP) == value:
self._preset_mode = preset
break
else:
self._preset_mode = PRESET_NONE
# Update the HVAC status
if self.has_config(CONF_HVAC_MODE_DP):
if not self._state:
self._hvac_mode = HVAC_MODE_OFF
else:
for mode, value in self._conf_hvac_mode_set.items():
if self.dps_conf(CONF_HVAC_MODE_DP) == value:
self._hvac_mode = mode
break
else:
# in case hvac mode and preset share the same dp
self._hvac_mode = HVAC_MODE_AUTO
# Update the current action
for action, value in self._conf_hvac_action_set.items():
if self.dps_conf(CONF_HVAC_ACTION_DP) == value:
self._hvac_action = action
async_setup_entry = partial(async_setup_entry, DOMAIN, LocaltuyaClimate, flow_schema)
