Known_devices.yaml cant find local pictures
Hi
I have added a folder called www within the same folder as my config file.
I have created a folder called local within the www folder and place my image in the local folder
This is in my know devices file, but
lm_s4mini:
  hide_if_away: True
  icon:
  mac:
  picture: /local/lm.jpg
  track: true
  vendor:
No picture is shown. If I put a web address of a picture then the picture is shown
I created the folders using Samba share, so not sure about permissions?
If I ssh into my PI the sudo command does not work in Hass.io so I dont know haw to change permissions.
Any clues
Regards Dave
Try to force refresh Browser. Or delete Browser Cache.
I had the same Problem. A few days ago, I changed a file. In some browsers and the iOS.app, Home Assistant still shows the old picture.
www/ is local/
place your picture in the www/ root inside the homeassistant dir and your syntax is correct. If you’re using www/local then you need to reference the file via
/local/local/lm.jpg
you are right. I have not read correctly :upside_down_face:
Thanks, now working, looking at other posts there seems to be confusion over this.
Did not know that WWW was Local
Many thanks for your help
Regards, Dave
So I have hass.io installed and used samba to create a www dir in my config directory (same folder my configuration.yaml is located).
I use /local/image.jpg to try and show an image. I can never get an image to display though. Always just a blank icon. I have no idea what I’m doing wrong. I have tried doing this multiple times and cannot get an image to display.
Here is a screen dump of main folder
main folder
here is the contents of my www folder
www folder
known_devices.yaml file
lm_s4mini:
  hide_if_away: true
  icon:
  mac:
  picture: /local/lm-beech.jpg
This is what I have and works a treat
Re Dave
does not help to delete cache or refresh
picture: /local/test.jpg
track: true
vendor: Apple, Inc.
you have to restart hassio every time you add a picture, then it works
I am running Hassio, I seem to recall it being different in my old set up.
What are you running?
Yeah, my folder looks exactly like that. Again created with Samba not SSH (because I have no idea how to create the directory properly with hass.io) Add a photo to www then restart HA and still just blank
Hi, like I created my with Samba, have you tried another jpeg?
Do you want to post the relevant parts of you config, I am happy to have a look.
Regards, Dave
Oddly I got two jpegs to work. Both of those were downloaded from websites. The ones I can get to work are jpegs from photos I’ve taken.
Are there any sort of size limits to them? I’m considering that as the issue.
Hi Ciwyn
Not sure if size is an issue (No jokes) but mine are 25K (184px x 177px 96 dpi).
Re Dave
I am also having issues with this. I am running hassio on a RPi3. I used samba from a windows10 machine to create the www folder in the config folder which contaings my .yaml files. I then put a picture in the www folder and linked to it in the know_devices.yaml file. I used /local/picname.jpg as the path. When I restart hassio, it just hangs and never comes up. If I remove the path to the picture in the known_devices.yaml file, then hassio comes up normally.
Did you try without icon: and picture: at the same time (even while only 1 of those is populated)?
This is what worked for me:
  picture: https://my_domain.duckdns.org/local/my_picture.jpg
I did what RonJ103 did and it worked, so long as the file size was small enough. I guess when you’re running a DDNS service the address needs to reflect this. I couldn’t get a 167kb file to work, but a 68kb did. Also had to clear the browser cache.
When I try that This site can’t be reached
https://mydomain.duckdns.org refused to connect.
Do you have duckdns setup?
