Any one here with KNX tried 1Home Bridge? Getting KNX to HA is ok, but then how to get things into Google Home. the I can export the ETS file and import it into 1Home Bridge with no problems, but that leaves out the non-KNX devices defined in HA out of Google Home like Shellies especially those that are added to groups that were originally connected via KNX.
I didn’t go through it, but I keep getting a new integration discovered for ESPHome and it says 1Home. This might be the way!! However, I don’t want to make a complex loop before I am sure what to do and how so I don’t endup with a million places to edit if I need to make a tiny change
I guess the 1Home thing just uses an esp internally and discovery sees a known MAC address (vendor part). But not sure since I own neither of these things. Maybe have a look here Google Assistant - Home Assistant
