The current knx light configuration allows to specify 4 individual colours for RGBW lights. There are now quite a lot RGBWW lights and led strips available and I wonder if there is a way to use these in KNX.
I have 5in1 led strips controlled by a MiBoxer 5 in 1 DALI controller that will give you 5 DALI addresses to control the led’s individually. As far as I can see I the KNX DALI Gateway DG/S2.64.1.1 from ABB does not have an option to create a CT control group.
The only way would be to control the 5 led’s individually from HA. Did anyone successfully integrate and control 5in1 led strips using HA and knx?
