Hi all,
I’m integrating a Zennio KLIC-DI v2 (Daikin gateway) that uses true percentage fan objects (DPT 5.001).
According to the official docs, this configuration should give a continuous 0–100 % slider:
knx:
climate:
- name: "Kal's Office AC"
temperature_address: "3/5/7"
temperature_step: 1.0
min_temp: 17.0
max_temp: 27.0
on_off_address: "5/0/15"
on_off_state_address: "5/1/15"
target_temperature_address: "5/4/5"
target_temperature_state_address: "5/5/5"
controller_status_address: "5/2/5"
controller_status_state_address: "5/3/5"
fan_speed_address: "5/6/5"
fan_speed_state_address: "5/7/5"
fan_speed_mode: "percent" # ← explicitly set
fan_zero_mode: "off"
swing_address: "5/6/6"
swing_state_address: "5/7/6"
What I actually get in the entity state:
fan_modes: off, low, medium, high ← discrete strings → dropdown in UI
supported_features: 441
From what I understood looking at the code, the KNX climate platform hard-codes _attr_fan_modes = [“off”, “low”, “medium”, “high”] whenever fan addresses are present, regardless of fan_speed_mode: “percent”. This overrides the expected behaviour and contradicts the documentation, which explicitly says “uses a slider in the UI (continuous 0–100 %)”.
Is this intentional, or a documentation/implementation mismatch that should be addressed? Many Daikin/Zennio users would prefer the actual continuous slider (or at least an option to get it).
Home Assistant Core: 2025.11.3
Installation method: Home Assistant OS
Thanks in advance!
