Helle there,
i have a problem by the configuration from my climate on my knx.
This is my configuration:
- name: "KG Gang - test"
temperature_address: "3/0/1"
target_temperature_address: "3/1/1"
target_temperature_state_address: "3/2/1"
min_temp: 5.0
max_temp: 30.0
This is my configuration in ETS
![Screenshot 2024-05-07 180748](https://community-assets.home-assistant.io/original/4X/2/a/8/2a8d2eabb2dd58a045309cf7a2d1b2f5d5ed3927.png)
Can anyone help me?
farmio
(Matthias Alphart)
2
Hi
What is the actual problem?
thanks for your fast reply. I have a Problem with the Cooling and Heating Mode.
I have a central switch for the cooling or heating mode.
Then i have for each room a seperat entry for the setpoint:
I have no Idea for the configuration. I have found following entry in the docu:
The following values are valid for the heat_cool_address and the heat_cool_state_address:
0 (cooling)
1 (heating)
But by me i have 1 for heating und 0 for cooling
Any Idea?
farmio
(Matthias Alphart)
4
That’s the same
. If it is a typo, use some Knx logic or HA automation to invert it.
hmm ok thanks. can you give a an example for your yaml configuration from the knx ?
farmio
(Matthias Alphart)
6
That’s not going to help you. You can find examples in the documentation.
yeah sure, but i have no idea to invert it with a automation?
farmio
(Matthias Alphart)
8
