Hi all,
I’ve been running my HA + KNX installation up until recently on some version of 2023. Upgrading to the current HA version (2024.5.5) and my climate sensors are no longer working, hence I cannot read the current temperatures from my sensors.
As I have read the KNX integration changed somewhere around 2024.2 so that the attribute climate target_temperature_state_address is no longer optional in the configuration.
As of now I was only collecting the temperatures via KNX from my room-sensors / button switch (GIRA Tastsensor 3 komfort 2fach 1+1) and sending an on / off command to my valve to open / close depending on a logic I build within HA.
This logic is very basic as it basically opens the valve when the target temparature (which is a simple numeric helper with HA) below the measured current temperature (provided by KNX). This logic was working fine all along up until now.
In general (but also in KNX) i have the following setup:
A button switch (GIRA Tastsensor 3 komfort 2fach 1+1 ; middle part of screenshot) which turns the light on / off with the upper rocker switch and controls the cover with the lower switch. This can be seen in the attached screenshot. As you can see there is a “Raumtemperatur-Messung” on channel 64 which is the current temperature from that sensor sending to GA 4/2/2. This GA is what I’ve been reading all along!
There are several group addresses defined around temperatures (see lower part of screen) but only “Ist-Temperatur” (GA 4/2/2) is mapped to the above mentioned switch.
“Stellgröße” (GA 4/2/1) is the actual switch to open / close the valve. This one is mapped to my heating actuator (see upper part of the screen) as all the other rooms / valves are.
my current configuration.yaml looks like this and has been working up until 2024.2
knx:
climate:
- name: 'Temperatur Arbeitszimmer'
temperature_address: "4/2/2"
As described only GAs 4/2/1 and 4/2/2 have been relevant for me up until now. I have predefined GAs which are not mapped to any device which should serve as target temperature (GAs 4/2/3 and 4/2/4). I was trying to map those to either the heating actuator or the switch itself but there is no attribute I could map it to. I checked the available properties of both devices and there is nothing which might help. I can only activate / deactivate the measurement of the temperature on my switch, but that activates / deactivates channel 64. No new channels (like “target temperature”) appear, hence I cannot map the GAs 4/2/3 and 4/2/4 to anything.
I tried providing different constellation of GAs to the attribute target_temperature_state_address but the climate sensor returns no values, hence is not available, hence I cannot run my heating properly.
Here’s two examples which didn’t work:
knx:
climate:
# target_temperature_address: "4/2/2"
target_temperature_state_address: "4/2/3"
knx:
climate:
target_temperature_address: "4/2/3"
target_temperature_state_address: "4/2/4"
So now the following questions arise:
- Is there an easy fix to provide the attribute target_temperature_state_address and just send it somewhere? I don’t need that for my logic of heating. I tried some GAs which are not used (4/7/7) but that didn’t work.
- If not: where can I map the GAs 4/2/3 and 4/2/4 so they become “real” and send values to them. I cannot map them to the heating actuator itself nor the switch. Where can I define / map those GAs? To which device?
- would it be possible to simple knx.read the value of GA 4/2/2 (hence my switch collecting the current temperatures) and paste it into a helper which then shows the current value?
I happy to hear from you guys! Thanks!
