I was using a Loxone Miniseverver as my dashboard interface to my KNX system (many years ago that was a much cheaper solution than the GIRA server)
… but there were a lot of problems with my Loxone interface, so I’ve started to setup HA with KNX.
That worked great for about 1 week or so.
now nothing works anymore and in logbook I see this message:
‘KNX Interface Connection type became unavailable’
I must say that I have solved the issue with Loxone by replacing the SD card as this was giving the troubles to login. That is working fine again, but I guess since that was fixed the problem with the HA-KNX started. (Don’t know for sure)
Hi Thanks for the info, yeh need to dive into the KNX docu to level up my understanding.
Did a full restart of all my systems (loxone, HA …)
So far all is working fine for a couple of days - since than the second error did not appear anymore.
