Hi team,
since the latest 2024/8 update my thermostat doesn’t show cooling state anymore.
Right now it is set to cooling but it still shows heating.
Anyone an idea if thats a breaking change from the KNX adjustment or an bug?
Thank you
Hi team,
Thank you
It wasn’t intended at least… happens when you only have mode state, but no set address. It will work properly when you configure a set address (eg. heat_cool_address
) as a workaround.
Thanks @farmio especially for the great KNX contribution
I just looked in my yaml and I have it set but didn’t work
climate:
- name: "FLU Heizung"
temperature_address: "5/6/0" #Aktuelle Temperatur
temperature_step: 0.5
target_temperature_address: "4/1/1" #Sollwert
target_temperature_state_address: "4/1/18" #RM Sollwert
command_value_state_address: "4/1/20" #RM Stellwert
setpoint_shift_address: "4/1/4" #Sollwertverschiebung 2Byte
setpoint_shift_state_address: "4/1/19" #RM Sollwertverschiebung 2Byte
setpoint_shift_mode: "DPT9002" #2Byte
setpoint_shift_max: 10
setpoint_shift_min: -10
operation_mode_frost_protection_address: "4/1/8" #Betriebsart Frost
operation_mode_night_address: "4/1/7" #Betriebsart Nacht
operation_mode_comfort_address: "4/1/6" #Betriebsart Comfort
operation_mode_state_address: "4/1/23" #Betriebsart HVAC Status
heat_cool_state_address: "0/0/8"
Glad you like it
There is heat_cool_state_address
, but no heat_cool_address
in your yaml.
Ah got it - I thought reading the state is enough, since I switch heat/cool via another summer/winter object
But now with both entries mapped to heat/cool (state) and summer/winter (switch) it works. Thanks a lot
