after searching the docs and forum for two weeks I resort to posting my question:
I have multiple KNX controlled roller shutters with MDT jal-0810m.02 controllers.
All the windows have contact sensors which block the shutters from closing entirely to allow ventilation. This is implemented in the MDT controllers which force the shutter to be at least 25% open when the window is opened and close the shutter once the window is closed unless the shutter has been opened in the mean time. That all works as expected, but when I open a window while the shutter is open and then while the window is open either an HA automation or through the HA dashboard the shutter controller is told to close the shutter the shutter stays 25% open as expected but HA reports the shutter as 100% closed even though on the KNX busmonitor in HA I can clearly see the corresponding state address is reporting 25% open.
When the window is closed and the shutter is closed HA shows 100% closed (as exptected) and when I open the window the shutter opens by 25% and HA shows that correctly as well.
Expected behavior: I would expect HA to assume the reported state from the state address is the truth instead of seemingly guessing something.
cover:
- name: Küche Gaube
device_class: shutter
position_address: 3/3/46
stop_address: 3/3/45
position_state_address: 3/0/13
- name: Küche Süd
position_address: 3/3/44
stop_address: 3/3/43
position_state_address: 3/0/12
I use HA docker, core 2024.1.0, Frontend 20240103.3
