Hi guys, I need your help here since I’m really confused.
I have a KNX system that integrates with my Home assistant I recently started to create a shade (cover) in Home Assistant.which works when I use:
closed cover tilt and open, and also the full open cover and close cover:
But when I click the switch to position view, it is not working. (When i click to take the shade down 45% it show that in the GUI but nothing really happens.)
I’m having a hard time understanding why, and I hope you guys can help me.
The below error is the log of the KNX and I will also attach the Debug file
Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0x36]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description:Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0x36]" />"/>
Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0x21]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description:Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0x21]" />"/>
Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0xb5]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description:Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0xb5]" />"/>
Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0x6e]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description:Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0x6e]" />"/>
Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0xc7]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description:Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0xc7]" />"/>
Also, please look into my concern:
name: "Zohar Bedroom Shutter"
move_long_address: "3/1/6"
move_short_address: "4/1/6"
stop_address: "4/1/6"
position_address: "3/1/6"
position_state_address: "3/1/6"
travelling_time_down: 51
travelling_time_up: 61
And this is the output from the debug:
2023-10-27 15:52:19.791 DEBUG (MainThread) [xknx.cemi] Outgoing CEMI: <CEMIFrame code="L_DATA_REQ" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.127")" dst_addr="GroupAddress("3/2/2")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xa1]" />" />")" />
2023-10-27 15:52:19.794 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.1.70:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="22" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="110" cemi="1100bce0117f1a02020080a1" />" />
2023-10-27 15:52:19.796 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.1.70', 3671): 06100421000a04016e00
2023-10-27 15:52:19.796 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.1.70:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="110" status_code="ErrorCode.E_NO_ERROR" />" />
2023-10-27 15:52:19.828 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.1.70', 3671): 06100420001604017f002e00bce0117f1a02020080a1
2023-10-27 15:52:19.828 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.1.70:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="22" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="127" cemi="2e00bce0117f1a02020080a1" />" />
2023-10-27 15:52:19.828 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.1.70:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="127" status_code="ErrorCode.E_NO_ERROR" />" />
2023-10-27 15:52:19.829 DEBUG (MainThread) [xknx.cemi] Incoming CEMI confirmation: <CEMIFrame code="L_DATA_CON" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.127")" dst_addr="GroupAddress("3/2/2")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xa1]" />" />")" />
2023-10-27 15:52:19.829 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/2/2" payload="<GroupValueWrite value="<DPTArray value="[0xa1]" />" />" /> for Work Shutter: Up/Down: <CouldNotParseTelegram description="Payload invalid" device_name="Work shutter" feature_name="Up/Down" payload="<DPTArray value="[0xa1]" />"/>
2023-10-27 15:53:40.023 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/2/2" payload="<GroupValueWrite value="<DPTArray value="[0x6e]" />" />" /> for Work Shutter: Up/Down: <CouldNotParseTelegram description="Payload invalid" device_name="Work shutter" feature_name="Up/Down" payload="<DPTArray value="[0x6e]" />"/>
2023-10-27 15:53:40.390 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/2/2" payload="<GroupValueWrite value="<DPTArray value="[0x30]" />" />" /> for Work Shutter: Up/Down: <CouldNotParseTelegram description="Payload invalid" device_name="Work shutter" feature_name="Up/Down" payload="<DPTArray value="[0x30]" />"/>
2023-10-27 15:53:40.933 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/2/2" payload="<GroupValueWrite value="<DPTArray value="[0x17]" />" />" /> for Work Shutter: Up/Down: <CouldNotParseTelegram description="Payload invalid" device_name="Work shutter" feature_name="Up/Down" payload="<DPTArray value="[0x17]" />"/>
2023-10-27 15:53:41.593 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/2/2" payload="<GroupValueWrite value="<DPTArray value="[0x0]" />" />" /> for Work Shutter: Up/Down: <CouldNotParseTelegram description="Payload invalid" device_name="Work shutter" feature_name="Up/Down" payload="<DPTArray value="[0x0]" />"/>
2023-10-27 15:53:42.669 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/2/2" payload="<GroupValueWrite value="<DPTArray value="[0xff]" />" />" /> for Work Shutter: Up/Down: <CouldNotParseTelegram description="Payload invalid" device_name="Work shutter" feature_name="Up/Down" payload="<DPTArray value="[0xff]" />"/>
2023-10-27 15:53:53.274 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Incoming" source_address="1.1.15" destination_address="3/1/6" payload="<GroupValueResponse value="<DPTBinary value="0" />" />" /> for Zohar Bedroom Shutter: Position: <CouldNotParseTelegram description="Payload invalid" payload="<DPTBinary value="0" />"/>
2023-10-27 15:53:53.277 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Incoming" source_address="1.1.15" destination_address="3/1/6" payload="<GroupValueResponse value="<DPTBinary value="0" />" />" /> for Zohar Bedroom Shutter: Position: <CouldNotParseTelegram description="Payload invalid" payload="<DPTBinary value="0" />"/>
2023-10-27 15:53:53.278 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Incoming" source_address="1.1.15" destination_address="3/1/6" payload="<GroupValueResponse value="<DPTBinary value="0" />" />" /> for Zohar Bedroom Shutter, Target position: <CouldNotParseTelegram description="Payload invalid" payload="<DPTBinary value="0" />"/>
2023-10-27 16:06:57.401 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0x47]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description:Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0x47]" />"/>
2023-10-27 16:07:40.145 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/2/2" payload="<GroupValueWrite value="<DPTArray value="[0x78]" />" />" /> for Work Shutter: Up/Down: <CouldNotParseTelegram description="Payload invalid" device_name="Work shutter" feature_name="Up/Down" payload="<DPTArray value="[0x78]" />"/>
2023-10-27 16:07:44.169 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0x87]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description="Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0x87]" />"/>
2023-10-27 16:07:44.920 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0x4f]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description:Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0x4f]" />"/>
2023-10-27 16:07:45.410 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0xbf]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description="Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0xbf]" />"/>
2023-10-27 16:07:45.916 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0x36]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description:Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0x36]" />"/>
2023-10-27 16:07:46.688 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0x87]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description="Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0x87]" />"/>
2023-10-27 16:07:47.176 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0x21]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description="Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0x21]" />"/>
2023-10-27 16:07:47.747 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0xb5]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description="Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0xb5]" />"/>
2023-10-27 16:09:04.390 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0x6e]" />" />" />
2023-10-27 16:09:04.390 DEBUG (MainThread) [xknx.cemi] Outgoing CEMI: <CEMIFrame code="L_DATA_REQ" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.127")" dst_addr="GroupAddress("3/1/6")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x6e]" />" />")" />
2023-10-27 16:09:04.393 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.1.70:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="22" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="126" cemi="1100bce0117f19060200806e" />" />
2023-10-27 16:09:04.394 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.1.70', 3671): 06100421000a04017e00
2023-10-27 16:09:04.394 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.1.70:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="126" status_code="ErrorCode.E_NO_ERROR" />" />
2023-10-27 16:09:04.427 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.1.70', 3671): 061004200016040190002e00bce0117f19060200806e
2023-10-27 16:09:04.427 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.1.70:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="22" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="144" cemi="2e00bce0117f19060200806e" />" />
2023-10-27 16:09:04.427 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.1.70:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="144" status_code="ErrorCode.E_NO_ERROR" />" />
2023-10-27 16:09:04.428 DEBUG (MainThread) [xknx.cemi] Incoming CEMI confirmation: <CEMIFrame code="L_DATA_CON" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.127")" dst_addr="GroupAddress("3/1/6")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x6e]" />" />")" />
2023-10-27 16:09:04.429 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0x6e]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description:Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0x6e]" />"/>
2023-10-27 16:09:06.234 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0xc7]" />" />" />
2023-10-27 16:09:06.234 DEBUG (MainThread) [xknx.cemi] Outgoing CEMI: <CEMIFrame code="L_DATA_REQ" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.127")" dst_addr="GroupAddress("3/1/6")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc7]" />" />")" />
2023-10-27 16:09:06.236 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.1.70:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="22" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="127" cemi="1100bce0117f1906020080c7" />" />
2023-10-27 16:09:06.237 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.1.70', 3671): 06100421000a04017f00
2023-10-27 16:09:06.237 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.1.70:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="127" status_code="ErrorCode.E_NO_ERROR" />" />
2023-10-27 16:09:06.268 DEBUG (KNX Interface) [xknx.raw_socket] Received from ('192.168.1.70', 3671): 061004200016040191002e00bce0117f1906020080c7
2023-10-27 16:09:06.268 DEBUG (KNX Interface) [xknx.knx] Received from 192.168.1.70:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" TotalLength="22" /> body="<TunnellingRequest communication_channel_id="1" sequence_counter="145" cemi="2e00bce0117f1906020080c7" />" />
2023-10-27 16:09:06.268 DEBUG (KNX Interface) [xknx.knx] Sending to 192.168.1.70:3671: <KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_ACK" TotalLength="10" /> body="<TunnellingAck communication_channel_id="1" sequence_counter="145" status_code="ErrorCode.E_NO_ERROR" />" />
2023-10-27 16:09:06.269 DEBUG (MainThread) [xknx.cemi] Incoming CEMI confirmation: <CEMIFrame code="L_DATA_CON" info="CEMIInfo("")" data="CEMILData(src_addr="IndividualAddress("1.1.127")" dst_addr="GroupAddress("3/1/6")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0xc7]" />" />")" />
2023-10-27 16:09:06.270 WARNING (MainThread) [xknx.log] Can not process <Telegram direction="Outgoing" source_address="1.1.127" destination_address="3/1/6" payload="<GroupValueWrite value="<DPTArray value="[0xc7]" />" />" /> for Zohar Bedroom Shutter, Up/Down: <CouldNotParseTelegram description="Payload invalid" device_name="Zohar Bedroom Shutter" feature_name="Up/Down" payload="<DPTArray value="[0xc7]" />"/>
Please note that I didnt really know what to fill in under Position* in the configuration.yaml file, but the tile function works.
i used the same configuration as the composer:
Regards,
Asaf
