i am currently switching from openhab 3 to HA. I have a running KNX system at my home. I was able to implement the knx add on and add all my knx entities by split yaml configuration. Everythink works like a charm. But now i am stucking at sending the date and the time and a day/night state to my knx bus.
Day/Night:
What i know so far is, that i need a toggle switch in HA which i can then send to a knx address. I tried to add this toggle switch by a helper (Settings → Devices & Services → Helpers) but i can not set the platform and the knx address in the HA UI. I am refering to this post:
The link shows a yaml configuration, but don’t know how to add this switch correctly by yaml. Is there a way in the UI to add this switch with the properties from the post?
I tried to add it to my config file. Testing the config file shows that everything is working, but after restarting HA the entity is not shown in my entities.
DateTime/Date/Time:
I also need this three properties on my bus. I have an address for each of them. But how can i get them to my knx bus?
I hope someone can help me. Please be lenient with me, because i am absolute beginner in configure and using HA, but i need to get up my system running.
Hi!
How to expose date and time to the Knx bus is explicitly written in the documentation. See Knx expose
There is also documented how to configure a switch. This is not possible from UI - only yaml. You may set the switch to respond_to_read: true to have it keep its state and answer to requests. In an automation just turn it on/off on Your desired day/night change time.
If you already have some kind of binary_sensor in HA for das/night you may just use expose to send that state change to the bus.
Very nice!
Day/Night is now working with a toggle switch, and i think i will also get date and time runing.
But i have one more question. The toggle switch, i crated in helpers, is setting the day/night state reverse. When i turn it on, i sets day state. Turning of, sets it to night state. Can i reverse the toggle switch?
If i can’t do it, how can i create a “revers toggle” switch?
How did you configure it? There are many ways… via expose you can’t invert - you’d have to create an inverted helper binary_sensor.
Or you create an automation using the knx.send service.
Via a Switch you can just configure invert: true.
