Hello everyone, my IoT devices are all KNX based. So far I was able to include basic elements. I added my dimmable lights but if I turn on the lights from my knx switch or another supervisor, HA doesn’t get the info. But if I do the changes in HA, the information is transfered to the other units. The code is straight forward, so I don’t know what I am missing. Here is what I am using:
Your definition in HA looks good I think. So maybe there is a problem on the ETS side. Could you add a screenshot from the GA assignment in ETS? The screenshot should also include the flags.
I’m on vacation in a few hours, so maybe I’m slow in answering, but I’m sure also someone else can have a look on it.
So my installer sent me the data but in PDF file… and in french. I will try to translate…
What is written after the # is what I translated from french.
So here is what I have:
light:
- name: "Wohnzimmer"
address: "0/0/4" #On/OFF
state_address: "0/0/34" #State
??_address: "0/0/64" #dimming control
??_address: "0/0/94" # variable value in %
??_address: "0/0/124" #variable value indicator in %
light:
brightness_address: "0/0/94" # variable value in %
brightness_state_address: "0/0/94" #variable value indicator in %
you have the same GA for brightness and brightness_state - maybe this is a typo. If not it should also work this way if the GA is readable (read flag) - otherwise you will get some errors in the logs complaining about this address not responding - you can remove it then.
Thank you @farmio , indeed the last address is 124, I corrected it. Magically it started working but it broke my automatically generated dashboard: TypeError: undefined is not an object (evaluating ‘e.entity_id’)
I used the same values before and it wasn’t working. Maybe it had something to do with the update…
