Hello forum,
I am using Home Assistant 0.115.2 as a docker container on a timberwolf server 950. Using the knx integration I am connecting to a KNX/IP gateway via tunnelling. This works fine after (re-)starting HA - I am able to send and receive KNX information with several entities. BUT: After a short time several errors occure in the log:
<CouldNotParseKNXIP description="KNXIP data has wrong length" />
21:39:11 – /usr/local/lib/python3.8/site-packages/xknx/io/udp_client.py (ERROR) - Die Nachricht ist zum ersten Mal um 21:39:05 aufgetreten und erscheint 3 mal
CEMI not supported: <UnsupportedCEMIMessage description="CEMI too small. Length: 10; CEMI: b')\x00\xb0P\x11\xca\x11\xcc\x00\x81'" />
21:39:11 – /usr/local/lib/python3.8/site-packages/xknx/knxip/tunnelling_request.py (WARNING) - Die Nachricht ist zum ersten Mal um 21:39:05 aufgetreten und erscheint 3 mal
Error: KNX bus responded to request of type 'ConnectionState' with error in 'ConnectionStateResponse': ErrorCode.E_CONNECTION_ID
21:39:09 – /usr/local/lib/python3.8/site-packages/xknx/io/request_response.py (WARNING) - Die Nachricht ist zum ersten Mal um 21:39:03 aufgetreten und erscheint 7 mal
Heartbeat failed - reconnecting
21:39:09 – /usr/local/lib/python3.8/site-packages/xknx/io/tunnel.py (WARNING) - Die Nachricht ist zum ersten Mal um 21:39:03 aufgetreten und erscheint 2 mal
Failed to update: connection error
After a while (some minutes up to an hour) the connection to the KNX/IP Gateway is lost and I can not send telegrams on KNX any longer. After a HA restart it works again until all happens again.
I found the same topic here but without a solution : link
Can somebody help me analyzing this?
my confuguration.yaml:
knx:
rate_limit: 20
tunneling:
host: '192.168.178.38'
port: 3700
local_ip: '192.168.178.2'
Thank you, Stefan.
