Hi friends,
i got problem,HA on Rpy 4 cant get KNX bus reading ,this is the mesagge:
Logger: homeassistant.config
Source: config.py:454
First occurred: 12:14:51 PM (1 occurrences)
Last logged: 12:14:51 PM
Invalid config for [light]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 10). Please check the docs at Light - Home Assistant
and i tried only one light,there is a yaml part:
KNX IP interface
knx:
Rasvjeta
ON/OFF rasvjeta
light:
- name: Soba
address:0/0/7
Loads default set of integrations. Do not remove.
default_config:
Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
can sombody tell me what im doing wrong,
KNX integration is all automatic,KNX IP router working ok,couse i can see KNX bus over mine Wi-fi,
thanks in advance.
Mvinceti
