Hello everyone,
I would like to use Home Assistant to control my air conditioning system via KNX. I have written the following code:
climate:
# Klimaanlage Schlafzimmer
- name: "Schlafzimmer Klimaanlage"
temperature_address: "5/2/2"
target_temperature_address: "5/2/0"
target_temperature_state_address: "5/2/1"
min_temp: 16.0
max_temp: 30.0
temperature_step: 1.0
controller_mode_address: "5/2/3"
controller_mode_state_address: "5/2/4"
controller_modes:
- "Off"
- "Cool"
- "Heat"
- "Fan only"
The temperature setting works. However, I cannot set the operating mode because the values for the operating mode that are sent via Home Assistant are not the ones I need. The following values are sent:
Off: 6
Cooling: 3
Heating: 1
Fan only: 9
However, I need the following values for my air conditioning system:
Off: 0
Cooling: 1
Heating: 2
Fan only: 3
So how can I change the default values sent by Home Assistant?
