Issue:
The light doesn’t OFF/ON when I change toggle available under the configured entity. However the strange thing is that I can see telegram sent to knx bus in ETS diagnostics Group Monitor.
Thank you for fast reply regarding your question I’m using secure tunneling.
To be honest I don’t know if the image is proof for anything but in general in ets I see that telegrams are coming from tunnel 8, which I setup for the HA
Yes, it is. The tunnel is on 1.1.8 and device is on 1.1.11
Oh and if you use Data Secure as well: that’s not supported by HA.
Just to be on the same page. There is support to connect by secure tunneling but there is no support to sent Data Secure?
So either use a proxy then
Would you be so nice and give me a little bit more information about the possibilities like this proxy? I am quite new to the topic and I am just trying to figure out things to connect dots
use plain on TP
So basically I should turn off the secure part in my devices and see if it will work as expected?
Exactly. Sending and Reading Data Secure Payloads is not supported.
I’m not quite sure as well, just heared that there are such things in the make. Never used Data Secure myself. I have a Jung IP Secure Router which supports to forward Data Secure Telegrams as non-secured Telegrams somehow, but also have not tested this.
Data Secure, yes. IP Secure (Secure Tunnelling) is well supported.
