Data Secure, in contrast to IP Secure, doesn’t have to be supported by the interface itself. (You are already receiving these frames as you can see in the log warnings )
Which model are you using?
Aah, I’m sorry. I’ve confused 0b1111110001 (0x3F1 Secure APCI) with 0b1111101011 (0x3EB) which stands for A_GroupPropValue_InfoReport-PDU. No idea what that is and why it is not implemented - may be some KNX RF specific stuff. But it shouldn’t raise a warning. I’ll look into it. Nevertheless, you can safely ignore it.
Hi, im now on Home Assistant 2023.3.3 and still got these errors.
I have devices with Secure AND the Connection is via Data Secure. Import all Keyrings etc.
At all i have big problems with the installation. Some GAs totally unavailable (checked all other possible mistakes) and some GAs sometimes unavailable and sometimes worked without problems. At all after a reload it took minutes till the connection work on the devices.
Thanks for help
