I want to integrate a KNX System into my Home Assistant project.
The KNX integration states that KNX Secure is not supported yet.
Does that mean i cant access a KNX Secure System by no means or is it possible to deactivate KNX Secure on the IP-KNX Gateway that is connected to a Secure KNX-System?
It should be possible to not use Secure with any interface. Every knx-secure device can be used non-secure.
Be aware that it may not be possible to run both, secure and not-secure connections, with one device - so one or the other.
Also if your interface is non-secure, knx-data-secure encrypted telegrams will still be transmitted - HA can’t parse them. I’m not sure if there are interfaces available that can encrypt and decrypt communication.
Edit: “Enertex® KNX IP Secure Interface” can apparently do just that.
Disclaimer: I have never used secure personally so just try and please let us know how it went.
