KNX Integration // Type Number // step value
Hello everyone,
according to the KNX integration documentation, it should be possible to define a step value for the type number.
When I try this, the code shows “Proberty step is not allowed”.
In my case, I would like to adjust the temperature in 0.5 degree steps.
How can i implement that?
Many thanks for your help.
Regards.
Flo
Hi :wave:!
Can you post the exact yaml which raised that error (in code tags ```)?
And maybe the exact error message?
Cant help you with KNX … but what would work is a input_number and a automation which updates the KNX element if the input_number changes.
thank you for your quick reply.
Here is the code:
number:
 -name: "SOLL Temp Büro"
      address: "1/2/1"
      respond_to_read: true
      type: temperature
      min: 18
      max: 24
      step: 0.5 *Property Step is not allowed.*
      mode: slider
Thanks in advance for your help.
Regards.
Flo
Ah, I see. This error is emitted from the VSCode plugin. Unfortunately this is not always 100% accurate in validating input - and in this case it seems the step key was just forgotten :grimacing:
Nevertheless, just save that config and run HAs internal config validator:
Developer Tools → YAML → Check Configuration
It will work just fine.
OMG, it worked.
Thanks a lot for your help and providing a solution.
Regards.
Florian
