Dear all,
from time to time I face the issue, that my MDT IP Interface for accessing KNX bus, stops to work. I reserved four different tunnels (1.1.1-1.1.4) in ETS, which are working quite good. In daily life, only one tunnel is active (Home Assistant).
Today again, the interface stops to work. No reading/writing to the bus was possible:
I found those lines from error log
2025-11-21 17:54:29.579 DEBUG (MainThread) [xknx.ga_dpt] No transcoder found for DPTs: {"{'main': 1, 'sub': None}"}
2025-11-21 17:54:29.580 DEBUG (MainThread) [homeassistant.components.knx.project] Loaded KNX project data with 328 group addresses from storage
2025-11-21 17:54:29.582 DEBUG (MainThread) [homeassistant.components.knx.storage.config_store] Loaded KNX config data from storage. 2 entity platforms
2025-11-21 17:54:29.583 INFO (MainThread) [xknx.log] XKNX v3.10.1 starting tunneling_tcp connection to KNX bus.
2025-11-21 17:54:29.653 DEBUG (KNX Interface) [xknx.log] Starting tunnel to 192.168.178.4:3671 over TCP requesting individual address 1.1.3
2025-11-21 17:54:32.729 DEBUG (KNX Interface) [xknx.log] Could not establish connection to KNX/IP interface. OSError: [Errno 113] Connect call failed ('192.168.178.4', 3671)
After power-cylcing the interface device, everything is working as expected. Does anyone has an idea, how this situation can be solved? Is this Home Assistant related, or MDT Firmware, or MDT hardware?
