Hello everyone,
since the KNX configuration is differently in 2022.4.5, I did all the corresponding adaptations, but no chance of getting the KNX integration to work. Before the update, everything regarding KNX worked fine.
Here the KNX part from the configuration.yaml:
knx:
#tunneling:
# host: x.x.x.x
# port: 3671
# local_ip: y.y.y.y
#sensor: !include solar.yaml
sensor: !include knx_sensor.yaml
cover: !include knx_cover.yaml
light: !include knx_light.yaml
and the knx_light.yaml as an example
- platform: knx
address: '1/1/21'
state_address: '1/4/27'
- platform: knx
address: '1/1/71'
state_address: '1/4/29'
- platform: knx
address: '1/1/81'
state_address: '1/4/9'
brightness_address: '1/2/0'
brightness_state_address: '1/4/8'
The KNX integration is set to automatic (also tried to configure manually)
Every entity is unavailable and here are some error messages:
- Unable to find referenced entities light.Technik
- The knx platform for the light integration does not support platform setup. Please remove it from your config.
- The knx platform for the cover integration does not support platform setup. Please remove it from your config.
Hopefully someone can help me with this issue.
Regards
