I have a " Gira 514200 KNX tastsensor 3 Plus 2-voudig" wich allows for “Alarm messages”
there are 2 inputs for this. a string for the alarm message and an enable/disable “switch”
So i found KNX - Home Assistant
As group adress i added the “message”
For the enable/disable i guess a simple lightswitch.
When sending a test message from ETS5 everything is working fine.
However i can’t find how to get this working in homeassistant.
Under “developers tools” > Service there is an “notify.knx_alarm”
but that is as far is i can come. i expect it to be so deadly simple that nobody has ever asked it as i couldn’t find any example.
My final goal is to link it to an existing mqtt topic. when the topic gets updated the switch should follow along. for some time. if not confirmed at the switch. the alarm should be cleared automatically.
