KNX Operation Mode not working
Hello guys,
I just set up my HVAC. However, I just saw that the presets are not working (comfort, standby, eco, building protection).
HA yaml config attached.
ETS AKH channel setup attached.
Logs attached.
The problem is that when choosing whatever preset, in the logs the setpoint is either not changing or it is changing for a second and then again back to the old state. Example: The thermostat is currently on Building Protection (7 degrees) and then when click on Comfort it is either not changing or it goes to 22 degrees and then again back to 7 degrees. However, the preset is staying as the one that is being clicked.
Thanks in advance for the help!
yaml config
