KNX - Scene Switch Control 🎬
With this blueprint, you can use a knx switch with a 1 Bit Object to switch through scenes. This is useful if you have a pushbutton and you want to use multiple scenes with one button press.
Source: KNX - Scene Switch Control
Version: 1.0.0
Requirements
  • Working KNX Integration
Features
  • Switch through multiple scenes with a 1 Bit object
Setup
Import the blueprint and create an automation based on it. The blueprint is mostly self-explanatory.
You have to define the scene group address and the switch group address, that the blueprint should listen too.
When the value 1 is received, the next higher scene is sent and vice versa.
You also have to create a number_input helper to which the automation can save the last scene number that was sent
Please don’t hesitate to give me your feedback!
Have fun :v:
Changelog
  • V1.0.0 - Initial Release
Hi Torben,
Thank you for this great blueprint.
Could you maybe add an overflow feature?
So that when I reach the highest scene number, it jumps back to the first one?
That would be great.
Version: 1.1.0
  • [New Feature] - Overflow function implemented. Can be activated optionally
